Power duals vs. true duals
Old Jul 19, 2013 | 09:07 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Originally Posted by taconite
Don't worry about the "low end torque" how often are you down there around 2500 RPM when you really need a constant 90 ft-lbs of torque? True duals help high RPM horse power. Thats where the fun is! If you really dig cruising up mountain grades in fifth gear at 55 MPH build you engine around low end torque. If you like to get on the throttle and have some fun cam that thing for HP and let her breath with true duals. What do you want a Mack truck or a Mustang?
Different strokes for different folks.
I like lower RPM riding and 6 gear with some grunt.
My 'King and I like to stomp and strut like Tennessee Walker Studs...
Old Jul 19, 2013 | 09:21 AM
aces25's Avatar
aces25
True duals do sound better, especially if the bike has a cam upgrade - you get the recognizable lope. However, you do not get the benefits of exhaust scavenging of a 2-1 or 2-1-2 system.
As stated many times on here, usually the order for best power gain is:
1. 2-1 (D&D, Dragos, V&H Propipe, etc)
2. 2-1-2 (stock config, V&H Power Duals, Fuel Moto, Fullsac, etc)
3. 2-2 (V&H Dresser Duals, Rush TDs, Cobra TDs, etc)
Look at high performance builds and see what they run. I haven't seen one yet that uses true duals. The 2-1-2 is nice compromise, and for the most part it behaves similar to the 2-1. Both the 2-1 and 2-1-2 will be easier to tune with the CFRs than 2-2, but there are some one here who do have the CFRs with TDs and love them.
Make no mistake - these bikes are not Mustangs. They are heavy, low-rev, and high-torque. And they take some serious coin to turn them into performance machines.
Old Jul 19, 2013 | 09:32 AM
dirtdobber's Avatar
dirtdobber
On the track I want hp with high rpm's
On the street I want tq. usable power at my finger tips.
I want my numbers to start to pull good around 2,000 to 2,500 rpm.
I have had both, for the street you can not feel the difference. If you do you probably did more than change pipes.
Old Jul 19, 2013 | 09:43 AM
Smokey Stover's Avatar
Smokey Stover
My S&S Power Tune Duals have a smaller hidden crossover,most of the exhaust flow blows right by giving true dual sound, while still giving some volume(not sound,flow) and scavenging like a 2-1-2. I put the quiet inserts in the V&H turndowns for a bit more back pressure,theyre not very quiet thats for sure. The CFR's would probably have that deeper rumble tone.
Old Jul 19, 2013 | 10:35 AM
mgmmgm's Avatar
mgmmgm
Well, I am having my bike dyno tuned on the 25th, with recently installed MGS true duals. I will post that in my albums.
While it's apple and oranges, I did have a dyno done with power duals and monster rounds, with SE255 cams, that sheet is posted in my my albums.
It will be interesting to see how the two dyno sheets look, taking into account that the
cams are not the same.
Old Jul 19, 2013 | 11:12 AM
mkguitar's Avatar
mkguitar
OP, my concern with the PD's is that IF the bike is lowered, on a right turn, the cover on the X pipe can hit hard enough to relieve traction from the rear tire=low side slide.
also the clamp on the crossunder should be oriented so that it can't dig into a speed bump and tear the pipes off the bike.
sound is subjective- we all like our pipes and hate the other guys
mike
Old Jul 19, 2013 | 01:45 PM
ridedaddy's Avatar
ridedaddy
do the power duals do a better job of diverting exhaust to the left side muffler than the stock pipes?
Old Jul 19, 2013 | 02:14 PM
PHXBiker's Avatar
PHXBiker
Personally I like the clean and tight to the bike look of the V&H true duals for a dresser. On the PD I thought the crossover looked a little too sport bike for my tastes. Just my opinion. When I got them 6 months ago my HD dealer said he didn't like all the welds around the power chamber X crossover on the power duals and may cause issues down the road. Sure enough at the dealer this morning a guy in for service on his road glide had dropped his bike sitting still and the weld cracked and the pipe fell right off at the X.
Old Jul 19, 2013 | 02:25 PM
mike5511's Avatar
mike5511
Well start a new thread or something so we'll know to look in your album because I'm interested in the results and your opinion of the MGS exhaust.
Old Jul 19, 2013 | 03:08 PM
mkguitar's Avatar
mkguitar
Not that I noticed.
and not that It makes any difference to me...in theory, the system(s) work much like a 2/1 until the pressure of increased flow pushes gasses to the left side
mike
