2" Pullbacks
Old Jul 19, 2013 | 10:35 AM
gll's Avatar
gll
Default 2" Pullbacks
Question for the guys that changed to the 2" HD pullbacks and did not change the clutch cable. How did you reroute it? I am changing my stock bars and would appreciate any info.
Old Jul 19, 2013 | 04:35 PM
rebbe18's Avatar
rebbe18
Instead of bringing the cable through the hole in the inner fairing, you would route it up between the inner fairing and the gas tank.
Changes the look but if you are ok with how it looks, that's how to do it.
Old Jul 19, 2013 | 05:03 PM
gll's Avatar
gll
Thank you. That is what I was thinking but wanted to double check.
I will try it like that and give the bars a try out going to Sturgis. If I like them I will do a longer cable
Thanks again
Old Jul 19, 2013 | 08:41 PM
karbar99's Avatar
karbar99
Thanks again
I replaced my cable with a 3+ black cable from harley. The cost was less than $35 shipped. If you should decide to do this I can give you an old stock number which some online dealers still have in stock.
Old Jul 19, 2013 | 09:54 PM
BackRoader's Avatar
BackRoader
The original cable path is around the front and over the top of your stereo. Re-route the cable under it and out the original hole. Gives you a few extra inches.
Old Jul 20, 2013 | 01:11 AM
mike5511's Avatar
mike5511
How about just posting it right here?
Old Jul 20, 2013 | 06:40 AM
gll's Avatar
gll
Thanks for the replies. I am going to get started on the swap in just a few minutes. Really hope it helps on the tendinitis in the elbow
Old Jul 20, 2013 | 04:08 PM
karbar99's Avatar
karbar99
I would have but he was asking how to reroute the stock cable and I was only putting out there that I replaced mine with a 3+ stock harley black cable, not wanting to hijack the thread with what I done and if he should so decide to do this as well.
So, here it is to those that may want the information for future references.
This part number has been listed in many post's in the past as well if you do a search here.
NOP #38649-08
As I stated earlier a few select dealers or online vendors may still have this part in their NOP's.
Check with your local dealer and have them look it up in their h-d net.com, "parts locator".
All's well.
Old Jul 21, 2013 | 01:17 AM
mike5511's Avatar
mike5511
Thanks!
Old Jul 21, 2013 | 10:55 AM
gll's Avatar
gll
Rerouted the cable and came out of the original hole. Worked just fine. I like the way the bars feel.
Briguy1
Aug 13, 2022 05:31 PM
gnalen
Jun 19, 2018 04:04 PM
keith t
Apr 18, 2016 07:50 AM
dawg
Sep 10, 2007 05:34 PM
lp
Apr 11, 2007 12:50 AM
