rear sprocket????
Old Mar 1, 2007 | 02:59 AM
rmarion's Avatar
rmarion
Default rear sprocket????
I want to add one tooth to my rear sprocket.....
can this be completed without changing anything else??????
our belt does have an adjustment............
Thanks
Rick
Old Mar 1, 2007 | 03:02 AM
jeepster09's Avatar
jeepster09
Default RE: rear sprocket????
You may get the adjustment, but it throws off the speedo calibration. You can buy adapter to correct it for about $100.00.
Old Mar 1, 2007 | 10:01 PM
dog155's Avatar
dog155
Have you found a source to buy a one tooth bigger sprocket?You can do the countershaft sprocket that way.
Old Mar 1, 2007 | 11:26 PM
choochoo's Avatar
choochoo
The older touring bikes (01 and older) (don't know about newer haven't checked)
You could change out the front belt sprocket ( behind the clutch) to two teeth larger.
I think it was a 34 tooth then.
Reduced engine rpm in 5th I think about 300rpm or so.
My olde 98 road glide had this. Was fine level but uphill was a little doggy unless I was doing at least 75.
But did get about 50 to 55 mpg if I kept it easy on throttle.
But don't thinkchanging rear sprocket on new bikes would change the speedo.
New bikes are read off the tranny and that should not change anything.
Only a larger or smaller diameter tire should change that.
However your engine rpms would change.
sbaalman
Jan 19, 2016 04:14 PM
20RoadGlidin
Jan 29, 2013 06:46 AM
Shredding rubber
Oct 6, 2011 12:02 PM
dgriffith
May 11, 2008 09:32 AM
rmarion
Mar 8, 2007 05:13 PM
