DIY Air ride install
Old Jul 24, 2013 | 09:14 AM
squaredaway's Avatar
squaredaway
How about that parts list and switch location??
Old Jul 24, 2013 | 09:37 AM
slammed05fatty's Avatar
slammed05fatty
2) monroe shocks
1) viar 98c compressor
1) 30A relay
used 18'' of 1/8'' line came with shocks
all other line and fittings from frightprops.com
used 24'' of 1/4'' line
2) 1/4'' tees push connect
2) 1/4'' x 1/8'' reducers push connect
3) 1/4'' push connect x 1/4 threaded
1) 1/4'' close nipplle brass
1/4'' soliniod valve off ebay
2) small rolls or wire
1) harley saddle bag lock switch
2) peformance racing bushings for upper shock mount
4) 1/2'' x 2-1/2'' grade 8 bolts
2) 1/2'' grade 8 washers
4) small bolts, washers and lock nuts to mount compressor. (cant remember size)
mounted switch in dash in factory extra spot.
i believe that covers everything i used. i had a 4-way to use instead of the 2 tees but it didnt work as well in the space provided so i went with tees.
Old Jul 24, 2013 | 11:03 AM
squaredaway
do you have the monroe shock part numbers? and were?
Old Jul 24, 2013 | 11:13 AM
slammed05fatty
MA785 is part number for shocks. you can find them anywhere online or at local auto parts stores. i cant remember where i ordered mine from becuase it was over a year ago. i know amazon has them. are you looking to do this set up? if so do a search (air ride installed) and find the thread from 999 customs or outlaw bagger. they have great write ups and details. thats where i got most all my info from.
Old Jul 24, 2013 | 11:56 AM
Hogpro's Avatar
Hogpro
Former Sponsor
https://www.hdforums.com/forum/touri...installed.html
There is the thread.
Old Jul 24, 2013 | 09:57 PM
prosnowsk8er's Avatar
prosnowsk8er
Originally Posted by Hogpro
No issue. What year is your bike. Mine is an 05 so the older frame. Maybe that has something to do with it.
Mine is a 2000' but I did do 07 swingarm upgrade
Old Aug 15, 2013 | 10:06 AM
jrstar's Avatar
jrstar
I wonder is this will work with my 18/200 tire?
Old Aug 15, 2013 | 10:18 AM
slammed05fatty
I don't see why not. I have room all around the tire when laid out completely.
Just curious, Did you have to change anything to run a 200?
Old Aug 15, 2013 | 02:02 PM
jrstar's Avatar
jrstar
ITs on a 18" wheel. Nothing else changes but pretty tight clearance on the sides
Old Dec 5, 2013 | 03:32 PM
billytha's Avatar
billytha
Stage IV
I did the Monroe set up , but seems to bottom out , or there's a banging sound even aired all the way up . I saw the thread on maybe trans hitting swing arm just wondering if that's the case . This on a 2011 glide .
