Front brake pads
Old Jul 26, 2013 | 01:32 PM
Sandcrab's Avatar
Sandcrab
Default Front brake pads
I have the manual and know what it says about removing the lid from the master cylinder and removing some fluid when replacing the front pads.
With that said, has anyone tried pushing the new pads in while gently loosening the bleed nipple at the brake pad so fluid can escape, and then tightening it before any air can get into the system.
Last time, a small amount of fluid got on the master cylinder, and the paint is now bubbling up.
Think outside the box.
Old Jul 26, 2013 | 01:37 PM
Hogpro's Avatar
Hogpro
Former Sponsor
I have done it without removing the lid or the opening the bleeder plenty of times. Just push back gently on the pistons.
Old Jul 26, 2013 | 02:08 PM
AlaskaAviator's Avatar
AlaskaAviator
As long as you never added fluid to the reservoir you just squeeze the pistons and put it back together with the new pads. If you have added fluid there may not be enough room in the master cylinder to compress the pistons.
Old Jul 26, 2013 | 03:08 PM
TWIN CAM 96's Avatar
TWIN CAM 96
This is a true statement
Old Jul 26, 2013 | 03:15 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Just be sure you have room in the reservoir, and all is good.
Which pads you replacing them with?
How many miles did you get with the old set?
Old Jul 26, 2013 | 03:16 PM
acchd's Avatar
acchd
Good link I bookmarked Dawg posted awhile back.
http://www.motorcyclemetal.com/Download10.html
Old Jul 26, 2013 | 03:43 PM
Dr. Tiki's Avatar
Dr. Tiki
If you take the lid off the master cylinder and force the piston's open, you are likely to have a little geyser on your hand as the brake fluid shoots back into the reservoir (don't ask me how I know).
What I do now if just loosen the screws so I am not fighting the pressure.
A trick that I use... take an old tube sock, cut the top part off after a few inches. Take that part and roll it up so it's like a little donut and then place that around your master cylinder. The sock will catch and absorb any brake fluid that may spill over the edge.
Old Jul 26, 2013 | 03:48 PM
Juan L's Avatar
Juan L
Moderator
Originally Posted by Dr. Tiki
.......A trick that I use... take an old tube sock, cut the top part off after a few inches. Take that part and roll it up so it's like a little donut and then place that around your master cylinder. The sock will catch and absorb any brake fluid that may spill over the edge.
I have just the sock for that. It will drive the OL batty looking for the mate!
Old Jul 26, 2013 | 04:14 PM
AlaskaAviator
You don't have to do anything with the cover. As you push the pistons in the the diaphragm in the master cylinder will just compress. The top of the diaphragm is vented to the atmosphere. When you have the new brakes on and pumped up take the cover off and check the level. DON'T OVERFILL.
Old Jul 26, 2013 | 05:33 PM
skratch's Avatar
skratch
i figured that it came from the factory with this much fluid in it and brand new pads, and when i put new pads on, it should work fine. it's not like the master cylinder is making more fluid.....
so, not surprisingly, when i replaced the pads, i didn't mess with the master cylinder and i had no problems.
