loud Tick, NOT lifters.....What else?
The engine was rebuilt with a 103 stage 4 kit, new valve springs, 10.5:1 compression pistons, SE259E cams, compression releases, some head work, SE compensator, Clutch spring, something about stetching the heads (must be in the cylinder/head gaskets?)
Anyway, when he started it, he knew something was still wrong with the rear cylinder. He had the heads checked for cracks, no intake leaks, he had to look further. It turns out the rear fuel injector was only getting 50% of the voltage it was suppose to. After talking with Harley on the phone to see if there is any way to adjust it, Not the pulse width, but the actual voltage, Harley said the ECM was no good.
Of course, not only were they on National backorder, but if you do get one, it has to be brought to the dealership to be "married" to the bike with your VIN code in it. We found one dealership 50 miles away that had 1. I went and picked it up myself and brought it to the closest dealer to him where he brought the bike down as well. Once that was set I had to buy a new SE pro race tuner, could not use the one I had on the new ECM no matter how hard he tried. He installed the program, tuned it and off I went.
Got the bike back the day before my vacation, put over 700 miles on it and love it. Because I had only the 3.5" Rineharts on it, he had to cut almost all the baffle out of it for it to breath, so this sucker is Loud. Think i'm going to have to go with new larger mufflers soon.
All set for another 40,000.
On a side note, I just put a new/perfect pair of 4" rineharts with chrome tips in the touring classifieds...
So to answer your question, it started out as an electrical problem, but did cause damage to the cylinder. The oil was so hot in that cylinder it was coking in the piston ring grooves.
Why the rear cylinder wasn't shutting down at idle is another mystery, I swore I had it activated. It really wouldn't have mattered much, it was while It was requiring more fuel while I was riding that it was at it's leanest.
Mark
I'm not going to read through all the suggestions so if this has been mentioned, sorry! Check the upper motor stabilizer link right where it bolts to the frame. Sometimes that hole is filled with powder coat and although with a wrench, it feels tight, its not pulling the link tight against the frame. When this happens again, take and push hard on that link and see if he tick changes or goes away or if you feel it moving. Just a hunch! lol If that turns out to be it, you need to remove that bolt and tap the hole clean.
OK Scratch that! I guess I should have read the entire thread after all. Glad you found the issue!
