PC III USB specific questions
Old Jul 28, 2013 | 08:38 AM
howitzer88's Avatar
howitzer88
Default PC III USB specific questions
2006 Ultra, VH oval slip ons, Ness big sucker. Stock ECM. Currently with a Fuel Pak.
So I have a PC III USB that I never installed on my 04 Dyna. The label on the PC III has 805-510 on it. The dynoJet website calls for 807-213 map. Is there anything that is Dyna specific about the unit? With the new map flashed, will this work with my Ultra? Any issues that I should be aware of?
Old Jul 28, 2013 | 12:31 PM
BoonDock_Saint's Avatar
BoonDock_Saint
The part numbers are different. Double check on powercommander.com FYI with the PCIII don't wait until the check engine light goes out to start it. It's powered by the fuel injectors and will crank until the injector circuit is powered again.
Old Jul 28, 2013 | 12:45 PM
fabrik8r's Avatar
fabrik8r
What happens if you wait? Been running the PCIII for about 5 years, I always wait for the CEL to go out before starting, I haven't observed any negative effects.
Old Jul 28, 2013 | 03:38 PM
06Cummins's Avatar
06Cummins
thats opening a can of worms there. your going to get diferent opinions from different people. read the manual it does not say you must wait till the CEL light goes out. it states the CEL LIGHT WILL STAY ON FOR 4 SECONDC AFTER THE KEY IS TURNED ON.
i have read my manual over and over and there is nothing stating you must wait. now that being said this is my 2nd bike with PC III and have noticed they both start easier if i turn on the key and right away hit the start button.
Old Jul 28, 2013 | 05:57 PM
nvsteve's Avatar
nvsteve
It doesn't hurt anything if you wait, it's just not necessary.
This was a bit of an issue in 07 with the PC111. If you wait it takes a few revolutions for the engine to fire vs. instant ignition if you immediately hit the start button. It has been confirmed that there is no harm in not waiting.
Old Jul 28, 2013 | 09:24 PM
BoonDock_Saint
Nothing is going to happen. My bike just takes a lot more cranking if I wait. If not, it starts right up. I was just mentioning that because i had a problem and went to the PCIII website and found that information and it fixed my issue.
Old Jul 28, 2013 | 11:21 PM
fabrik8r's Avatar
fabrik8r
I appreciate the input on that little PCIII character flaw, it may be useful one day.
BarneyB
Sep 21, 2009 08:33 AM
phatbobby
Jan 5, 2009 07:51 PM
bigjames19
Dec 28, 2008 11:13 PM
Scubadog
Oct 20, 2008 03:49 PM
luckystars5
May 2, 2008 08:32 PM
