Cat removal
Old Jul 29, 2013 | 07:01 AM
ericl's Avatar
ericl
Originally Posted by firefighter616
1 1/2 line at 125 psi will knock a cat out of a tree a good distance..
True, but Handling on a power cone will keep the cat hemmed up in time to position the deck gun. You definitely achieve greater hang times
Old Jul 29, 2013 | 08:05 AM
lionsm13's Avatar
lionsm13
Set a nice trap or the humane society will be all over you for your cat removal. lolol.
Seriously though, just cut in half, remove honey comb and re-weld.
Why cut a window in it. Too much work.
Old Jul 29, 2013 | 08:21 AM
hardheaded's Avatar
hardheaded
drill it!
Old Jul 29, 2013 | 08:13 PM
Cep10SG's Avatar
Cep10SG
Well, you can drill it anyway you want, it's your bike. I'm just that **** that I don't want it to look like it was done. I've never had any measurement issues when I've done it and so far I've done about 8 pipes for friends. If your welder knows what the hell they're doing you shouldn't have any problems. I took many pics when I gutted my pipes and mufflers, for some reason i'm having issues uploading tonight, if you want to see them send me an email to see if it helps you in any way.
Cep
Old Jul 29, 2013 | 08:19 PM
RussH's Avatar
RussH
Originally Posted by rob0225
16" long 1" spade bit and a good drill.
+1 works like a champ.
Old Jul 30, 2013 | 04:49 PM
northeimcustom's Avatar
northeimcustom
how do you know you got it all/majority of it out??
Old Jul 30, 2013 | 06:49 PM
hardheaded's Avatar
hardheaded
look in there with a light and mirror, mine was clean as could be. every bit of it was out.
Old Jul 30, 2013 | 07:03 PM
Wubben551's Avatar
Wubben551
How about new head pipes? I'm kinda leaning that way with a screaming eagle tuner and some Rinehart slip ons. Looking at a heavy breather as well. Basically stage 1 I guess. Just looking for a little less heat and a little more zip. Bike is a 2012 Street Glide.
Old Jul 31, 2013 | 09:49 AM
billnourse's Avatar
billnourse
New head pipe is 500.00. Gutted cat is free if you know a welder. Difference in performance, according to a Dyno Chart at FuelMoto, between a Jackpot head pipe(479.00) and a gutless cat (2009 Stock) is 1.8 HP with near identical power and torque curves.
Bill
Old Jul 31, 2013 | 11:14 AM
hardheaded's Avatar
hardheaded
drill bit $10.00 bucks at lowes
