Cat removal
Old Jul 31, 2013 | 05:53 PM
Wubben551's Avatar
Wubben551
Wow hadn't priced new head pipes didn't realize they were that high. Thanks for the info.
Old Jul 31, 2013 | 07:55 PM
glmf's Avatar
glmf
I used 309 to tig weld mine. Worked fine
Old Jul 31, 2013 | 08:46 PM
GrumpyBear's Avatar
GrumpyBear
Originally Posted by ericl
True, but Handling on a power cone will keep the cat hemmed up in time to position the deck gun. You definitely achieve greater hang times
Helicopter and a Bambi Bucket. Less air more punch.
Old Jul 31, 2013 | 09:22 PM
skratch's Avatar
skratch
Originally Posted by Wubben551
How about new head pipes? I'm kinda leaning that way with a screaming eagle tuner and some Rinehart slip ons. Looking at a heavy breather as well. Basically stage 1 I guess. Just looking for a little less heat and a little more zip. Bike is a 2012 Street Glide.
Originally Posted by billnourse
New head pipe is 500.00. Gutted cat is free if you know a welder. Difference in performance, according to a Dyno Chart at FuelMoto, between a Jackpot head pipe(479.00) and a gutless cat (2009 Stock) is 1.8 HP with near identical power and torque curves.
Bill
or you could go with the fullsac sport pipe which is a stock headpipe, with the cat collector portion cut out, an entirely new collector welded in, and then ceramic coated inside and out. $279 with your old header as exchange.
http://fullsac.com/sportpipe.html
Old Aug 1, 2013 | 12:28 AM
sr_smyth's Avatar
sr_smyth
Default 02 sensor damage
for you guys who are championing the long spade bit method, is there any chance of hitting the o2 sensors doing it this way and do you have to start with a smaller bit first or go straight at it with the wide spade bit? cheers
Old Aug 1, 2013 | 08:37 AM
hardheaded's Avatar
hardheaded
i took my pipe off and removed the 02 sensors, put pipe in a vise and drilled it out in about half hour. i also put a shop vac on the end of the pipe as you don't want to breath the dust from the cat. none of this is very hard to do, i used a pry bar to scrape the inside of the pipe to. this method gets it very clean and beats the hell out of cutting and welding it back together. i have two welders right here in my garage and drilling was a better way to go.
Old Aug 18, 2013 | 02:13 PM
screamer56's Avatar
screamer56
6th Gear
Originally Posted by my67pnycar
Since nobody told you, Welcome to the forums Screamer. When you cut your cat out, cut along the length of the pipe in the oval big middle part of the pipe (thats where the cat is) cut a window out of 1/2 of that section, dig all the cat material out then clean with a flapper wheel or something, take it to a muffler shop and have them button it back up for less than 50 bucks, cheap DIY. Dont just cut the pipe in 1/2, you will loose length when you put it back together and things wont line back up. I am attaching the link for a thread that explains how to gut the cat DIY. If you do not feel like messing with it, you can get one already done from fleabay for round 100 shipped to your door, or google american customs, they do this also and they gut stock mufflers and have a link with pics and tools needed for exhaust removal and assembly. Also you can use the search feature on the top right by the advertising button under the fuel moto banner, type in what you want, click show threads hit go, whatever you are searching for will pop up. Hope this helps you out, stay safe out there..
https://www.hdforums.com/forum/touri...with-pics.html
http://www.americancustom.com/media/news/AmerCustom.pdf
Thanks for the info, sorry it took this long to reply, thing are getting crazy around here. Think I will cut it out myself, but will wait till after Labor day. when thing slow down.
Be safe out there, keep the wind in your face.
MikeRX
Jul 31, 2016 12:38 PM
aces25
May 6, 2013 08:52 PM
billnourse
20
Feb 28, 2013 01:03 PM
billnourse
Oct 2, 2012 08:28 AM
horseplay
"The Georgia Crew"
15
Sep 24, 2011 02:03 PM
