I finally learned what it means!
Old Jul 28, 2013 | 06:19 PM
TUCCI's Avatar
TUCCI
Default I finally learned what it means!
I was reading thru some tech tips on SS cycles website about lifters and pushrods and finally learned why after I shut down my bike more than 10 minutes my valve train makes a racket for at least 10-15 minutes of riding 'Bleed Down'. It doesn't do it if I get right back on it. I've got about 10 minutes to get back on or it will bleed down.
http://www.sscycle.com/feature/featureview.php?s_id=38
I still haven't learned why it only started doing that after close to 8k miles and never did it before. From what I understand from the article it's a normal function and can take up to 20 miles for it to pump back up. I don't remember that many miles going by but it's possible I start ignoring it after a few miles.
What it didn't explain is how i can postpone the bleed down longer than the time it takes mine. From the article it takes approx 20-30 minutes or longer for the bleed down to occur....that's sounds about right in my case.
Old Jul 28, 2013 | 06:21 PM
stro1965's Avatar
stro1965
I think if it takes 10 minutes for them to pump up you have faulty lifters. Might take that long the first time with new ones, but shouldn't with yours.
Old Jul 28, 2013 | 06:33 PM
TUCCI's Avatar
TUCCI
So is the instructions outlining pump up taking up to 20 miles talking about new lifters or all lifters? I ran my bike for about 130 miles yesterday and never got off more than 10 minutes and no bleed down occurred. Sometimes it doesn't take that long but if I get off for let's say an hour for lunch or whatever it does take a little while to pump back up?
Old Jul 28, 2013 | 06:59 PM
stro1965's Avatar
stro1965
I might be mistaken but I'm thinking they mean new lifters or lifters you've taken out and cleaned.
Old Jul 28, 2013 | 07:11 PM
ZenGlide's Avatar
ZenGlide
Default Need input to help ID my first strange engine noise
Disregard. Posted in wrong thread.
Old Jul 28, 2013 | 07:12 PM
jus2anoyu's Avatar
jus2anoyu
If your lifters clatter after sitting hot for 30 minutes or so, they are bad. Unless your bike is under warranty, then it's normal....
Old Jul 28, 2013 | 07:20 PM
TUCCI's Avatar
TUCCI
It is....under warranty. That's why I've been bonin up on lifters, I may be tackling it down the road. I don't want those idiots touching my bike let alone diagnosing it. The more I read about it, the more it sinks in. A matter of time before I know what I'm doing. Gaterman seems to be the lifter of choice the forum pro's are using. Guess I posted this thread in a continuing effort to increase my knowledge base with input from readers, absorbing what I can use and discarding the rest. Keep talking people, I'm listening.
Old Jul 28, 2013 | 07:23 PM
jus2anoyu's Avatar
jus2anoyu
I'm using the gatermans and can't complain. They are good lifters for the money.
Old Jul 28, 2013 | 07:24 PM
jus2anoyu's Avatar
jus2anoyu
If you decide to circumvent your warranty, get a set of the se tapered adjustable push rods to go with the gatermans. They are very nice quality...
Old Jul 28, 2013 | 07:40 PM
TUCCI's Avatar
TUCCI
That's what I hear, did you do them yourself or have it done? Did they rub against the rod covers or do they come with their own? What made you change from stock, same reason as I have or during a build?
