Pinging Road King
Old Jul 28, 2013 | 06:20 PM
KingSteve's Avatar
KingSteve
Default Pinging Road King
I have an '06 Road King with updates as follows; 95" kit, big sucker air, andrews 21 cams, and supertrapp 2:1 exhaust.
I have Powercommander III that was mapped at dealer a couple of years ago. When I ride alone, no problems.
When wife and I ride 2 up, the engine pings and diesels like crazy if I pull any kind of hill...
Do I need to have the thing re-mapped or am I missing something easy. I am planning to try
octane booster and I always run 91 octane fuel.....
Any guesses?
Old Jul 28, 2013 | 06:29 PM
TUCCI's Avatar
TUCCI
I had the same problem and what I did is I took extended rides and documented at what speeds and RPM's the pinging occurred. I then went into the ignition map and at the approximate speed/RPM/throttle % I removed (-) 1 degree at a time until all the pinging went away. Some of the fields I have up to -2 degrees but I've read where other members have removed more. Each bike is different so you have to experiment with your particular issue.
Old Jul 28, 2013 | 07:21 PM
jus2anoyu's Avatar
jus2anoyu
First, run a can of seafoam through the throttle body while it's running. Make sure you knock all the carbon out of the upper cylinder. Then, check your plugs. I went to a se plug for high compression engines and they work nicely. If this doesn't yield good results, throw in a can of octane booster and see if that helps. If all this doesn't work, you now have the optimum conditions to evaluate your bike to determine where fuel needs to be added or timing taken out.
AAAC
Aug 11, 2014 08:47 AM
CrashJones
Exhaust System Topics
Sep 15, 2013 06:28 PM
mallyhunt
Apr 27, 2013 09:18 AM
iatan1966
Mar 26, 2007 01:40 PM
Newhog
Mar 5, 2007 09:53 PM
