Road King running on one cyl.
Old Mar 5, 2007 | 12:16 AM
Newhog's Avatar
Newhog
Default Road King running on one cyl.
My brothers Road King started running rough on one cyl (front), missing, popping, backfiring etc.replacedthe plugs, nothing changed.It's getting fuel to the cyl so we know it's not that.
What would ya'll suspect? Bad plug wire or bad coil? Any other ideas?
We rode about 400 miles today, 60 miles on fresh gas, before problem started.
It's a 99 Road King Classic, EFI, stock except for high performance cam which was done years ago. No other mods. It's ran flawless until now. Serviced by the dealer per schedule.
Old Mar 5, 2007 | 12:22 AM
unclekunkle's Avatar
unclekunkle
Default RE: Road King running on one cyl.
ORIGINAL: Newhog
Swap wires and or coils...see if the same cyl is still dead...A similar scenario occured to a friend of mine...was a head gasket. gotta have compression. Hopefully though you'll be in the 95% that ignition is the culprit...let us know what you find.
Old Mar 5, 2007 | 09:32 AM
Grover's Avatar
Grover
Administrator Emeritus
It takes three things for an engine to run:
1) Proper air/fuel mixture
2) Adequate compression
3) A properly timed/adequate spark
You say you have fuel.
Have you run a compression test? If you have good compression and fuel delivery, it must be in the spark. Coil? Wire? Plug? Sensors? Just eliminate them one by one until you get it right.
Let us know what you find out.
Old Mar 5, 2007 | 11:57 AM
Newhog's Avatar
Newhog
Thanks Folks,
Sensors? Now that's one I've not thought of, let me be stupid and ask where they are or more importantly which one(s) you are reffering to?
Old Mar 5, 2007 | 12:30 PM
sleepneagle's Avatar
sleepneagle
you have an intake leak.
easy enough to check the plug fire, get an extra plug, connect to rear cyclinder spark lead, ground plug and turn engine over looking for spark.
Old Mar 5, 2007 | 01:13 PM
Newhog's Avatar
Newhog
ORIGINAL: sleepneagle
Intake leak? Where for example? How could that cause a fouled plug on the front cyl and not the rear? Not trying to be a smarta$$. Looking for an education here.
I am very appreciative.
Thanks, Mike
Old Mar 5, 2007 | 01:18 PM
choochoo's Avatar
choochoo
Well is it fuel injected?
The sensors in and of themselves will not cause to run on only one cylinder.
All they do is feed information to the Ecm to process so the ecm knows if it should
adjust time the injectors are turned on (squirting fuel) if it should advance or retard
the spark timing.
so........
Two things you should check is compression in that cylinder.
But since you claim it was sudden I would expect ignition.
one side of coil could be bad, or the plug wire.
It is possible but not likely, that the ECM is failing and not suppling a ground
for one side of the coil, or the wire from coil back to ecm is damaged.
In an old points system when the points opened (you lost the ground), the electrical magnetic field that was built up in coil, would collapse. thus generating the secondary high voltage spark.
In the Ecm it does the same thing. Through the transistors, it completes the ground and the coil field builds up. When the crank sensor sends a signal to ECM that number 1 or 2 piston is at the right point to receive spark, Ecm turns off the transistor. Now no ground on that circuit and the field in coil (as in points above) collapses generating the spark.
So I would venture most likely the coil or plug wire has gone bad.
Take a new plug and plug into wire. Ground the metal tang (electrode) of plug to engine.
Crank engine look for spark. No spark,take other coil wire off and move to the number one spot and the number 1 to number two and see if problem moves. If it does it is the wire.
If not try another coil.
But do a compression test to be sure.
Old Mar 5, 2007 | 02:19 PM
Manish_Hawg's Avatar
Manish_Hawg
Do you have a PCIII? I know you didn't say there was one installed. But my bike was acting like this and my PCIII would basically work when it wanted to and shut off. Dyno jet told me it had old firmware and had to update it.
Old Mar 5, 2007 | 02:49 PM
Newhog's Avatar
Newhog
No PCIII, bike is completely stock and is a fuel injected model.
Old Mar 5, 2007 | 09:45 PM
Hoopman's Avatar
Hoopman
heres is an idea that took my dealer days to come up with..... the petcock! Believe it or not.
(PS I know what you are thinking... dont go there!) [:-]
