Readjusting pushrods
Old Oct 8, 2013 | 09:04 PM
  #41
$tonecold's Avatar
$tonecold
Originally Posted by 5TIME
They told me to closely look at the video that they have as part of the series associated the the 107 kit build; the 12 minute piece that shows pushrod install and adjustment is where I got that from. They also told me "about 4 and a
third turns" when I have talked to them on the phone. When I get home I'm going to see if my instructions are any different. I'm glad to be hashing this out now. It seems that they are advocating a deeper adjustment as many are discussing on this thread.
Hey, when it says threads per inch it means just that. Pushrods come with 24, 32, & 42 tpi. When in doubt, count. It will be pretty obvious. You can use a tape measure. Then you divide the thread count into 1 and multiply by the depth you want. 1/32 x .125 = 3.000006
Three turns. Get it?
Old Oct 10, 2013 | 07:03 AM
  #42
5TIME's Avatar
5TIME
I talked to Fuel Moto to reconfirm turns, preload, etc. Since I have the TW222, directional lifters and their adjustable pushrods, they do in fact recommend 4 turns and two flats which is .130. He actually said .130 calculates or 4.19 turns. At any rate, he said I'd be fine over 4 and under 4.5, so I'll do exactly as instructed. The .130 is not inconsistent with those on this thread who have adjusted "deeper" to ~.125 in an attempt to quiet the bike. I only want/plan to go in there once, so I'll add the Zippers tensioners and the Axtell bypass.
Old Oct 10, 2013 | 12:10 PM
  #43
the warden's Avatar
the warden
.125 is "shallower" than .130, not deeper. However, the difference is negligible . I originally adjusted my FM pushrods with the TW222 to the 19 flats recommended in the instructions that came with the pushrods. They were noisy but I thought, well, I followed the instructions, so it must be right. Now after 5k on the new cams I readjusted them to 4.5 turns, 27 flats, and what a difference. Much quieter now.
Old Oct 10, 2013 | 12:14 PM
  #44
the warden's Avatar
the warden
Sorry, your math is not working out for me. Isn't 1/32 x .125 = 4.0000?
Old Oct 10, 2013 | 02:32 PM
  #45
5TIME's Avatar
5TIME
Got it. He did say that anywhere between 4-4.5 was fine; I'm glad to have found someone who installed the combo-(222s, directional lifters, and FM adj pushrods). I might err closer to the 4.5 number, given your experience. I absolutely hate doing things twice... Thanks for the info.
Old Oct 10, 2013 | 02:52 PM
  #46
$tonecold's Avatar
$tonecold
Yeah, late at night (for me), a few beers, you know. Should have been 1/24 x .125 = 3.00006
Old Oct 10, 2013 | 03:02 PM
  #47
the warden's Avatar
the warden
Been there! LOL
JDG1172
May 7, 2016 08:53 PM
Garrman
Engine Mechanical Topics
39
Dec 19, 2015 11:59 AM
cerelious
Aug 20, 2015 03:47 PM
Scrmnvtwins
Jul 10, 2015 06:10 AM
airchair10
Aug 23, 2010 09:05 AM
