Ride On users
Old Aug 1, 2013 | 02:36 AM
FallujahFF's Avatar
FallujahFF
Default Ride On users
I am getting some new wheels and tires for my bike and have heard great things about ride-on to help with balance and flat "issues".
Those that use that stuff--can you tell me if this is something I need to put in the wheel when the tire goes on or is it a "fix-a-flat" type application where you screw it in and let it spray in the already mounted tire?
Thanks!
Old Aug 1, 2013 | 03:18 AM
Watch Guy's Avatar
Watch Guy
Default You install it when you get the new tires
Thanks!
or you can install it any time after that, but not after a flat. It's just a thick liquid that gets injected into the tire via the valve stem. It's there to automatically seal a leak caused by a puncture. It's saved me 4 times already with nails I keep picking up in both the front and back tires. Only problem is, you need to always check your tires for nails or screws since the Ride On will keep the air and you may never know you have a nail unless you see it or it tears a bigger hole the Ride On can't seal. It also acts as a tire balancer so you won't need wheel weights when you use Ride On
Old Aug 1, 2013 | 05:40 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Probably a good idea to take your bike for a pretty good spin right after putting it in to kind of sling it around...
Old Aug 1, 2013 | 05:59 AM
MNPGRider's Avatar
MNPGRider
There's a short plastic tube that comes with the Ride On. One end goes over your valve stem, the other over the tip of the bottle cap, and you squeeze it in. I just installed some yesterday in my new tires on my small trailer, and I was impressed at how viscous it was even in the summer heat. I found that tapping the bottle with a screw driver while upside down attached to the tire helped speed up the process.
With five oz in those small 4.5" x 8 tires, that little trailer sure bounced for a few blocks until the Ride On spread itself out inside the tire !
Old Aug 1, 2013 | 06:56 AM
FallujahFF's Avatar
FallujahFF
Thanks Guys, sounds like nothing but beneficial to use!
Old Aug 1, 2013 | 08:06 AM
Pete6114's Avatar
Pete6114
Dont forget to take the valve out of the stem. and put the correct amount in it. Here is the dosage calculator.
http://www.ride-on.com/calculator.html
Old Aug 1, 2013 | 08:16 AM
EasTexUltra12's Avatar
EasTexUltra12
The indy that I get tires from charges extra if you have that stuff in your tire.
Ride Safe
David
Old Aug 1, 2013 | 08:26 AM
Pete6114's Avatar
Pete6114
Ride Safe
David
Ride on is not messy like some of the other products that covers everything. This sits on the thread area and wont make a mess when removing the tire. Had a tire replaced last week at a dealer and asked if there was any complaint from the wrench and was told NO. But if he gets more for it, all the power to him.
Old Aug 1, 2013 | 09:15 AM
EasternPC_Forum's Avatar
EasternPC_Forum
Former Sponsor
We were skeptical about Ride On for awhile, but after their rep came and demonstrated everything about the product in person (including drilling a hole in the tire and having our mechanic ride the bike at 80 mph right afterwards), we were sold. It doesn't void any warranties and it eliminates the use of wheel weights. We use it in pretty much every custom wheel setup we send out of here.
Old Aug 1, 2013 | 01:02 PM
Nute's Avatar
Nute
Had it in both my F & R Commander II tires. Balanced them out perfectly. BUT! Somehow I was able to cut the valve stem on my R tire @ 80 mph and lost all the air and the tire by the time I got to the shoulder of the interstate. I plan on putting it in my new R tire.
