do not tie your bike down...little known fact is that it may void your warranty starting with this years' bikes. you can't be wearing out any parts or breaking down with the bike on a trailer--so the moco is doing some limited testing in certain markets to increase service department profits. if initial testing goes as anticipated, all bikes will come from the factory with a transponder built into the frame. with satellite technology the moco will be able to determine when a bike is being trailered. for every 2 days that a bike is on a trailer(even if just a few minutes) you will lose one day of warranty.
I bought a set of nice tie down brackets that bolt onto the to of the forks, at the same place as the lamp brackets. Works very well and looks good too. Use it when traveling by train or/and ferry
I prefer to put my softies around the fender mounts of the lower forks. Then use rachet straps to tie the bike down. This allows the bike's front suspension to float and puts no stress on the seals. Your tire / wheel takes all the stress.
I then tie the rear down withe softies and rachet straps around the bag guards.
Also remember to put your kickstand up.
Good luck.
I go around the frame just above the cross brace. One on each side. Then I use one on each passenger peg bracket. I leave it in gear and have front wheel in a wheel chock
Also remember to put your kickstand up. , and down before you release them all the way , I keep a pink sticky note on my headlight so I don't forget [ again ] LOL
Looks like most of the guys who answered this thread! Makes me sick seeing these things "straped" down... 20 years ago I could never have imagined someone asking "how to strap down a bike" let alone a bagger!
