Got an Electrical Problem - Need Help
Old Apr 7, 2007 | 11:21 PM
  #51
doch4m's Avatar
doch4m
Default RE: Got an Electrical Problem - Need Help
Wally,
The HD part # for the screws is 1783C. I know that is good for 03's and 04's. You might want to double check that with your dealer/parts catalog for your 99.
Hope that helps.
Ride on, ride well.
Doug
"I took the one less traveled by,
And that has made all the difference."
Old Apr 8, 2007 | 01:24 AM
  #52
Wally's Avatar
Wally
Thanks Doug.
Interested to know if the link for the pictures works for anone but me?
Old Apr 8, 2007 | 10:39 PM
  #53
StL Mike's Avatar
StL Mike
Doug,
I'm curious about your front fender trim. Is that a RoadGlide fender? I've never seen that chrome on a Road Glide fender before. I'd be curious to knowwhat the part numbers are if you have them.
Thanks,
Mike
Old Jun 5, 2007 | 04:42 PM
  #54
frashr's Avatar
frashr
2nd Gear
doch4m -
Just want to say "wow" - I was searching on-line for information on how to replace my shifter shaft seal. Read your threads on changing out your stator (and shaft seal), saw your pics, andwas blown away at how much time you took to document and share with others. I wish service manualshad half thedetail!
Great job - and thanks!!
Old Jun 20, 2007 | 01:37 PM
  #55
Wally's Avatar
Wally
Doug, long time no talk.
how's the paint job coming on the Partridge Family Bike?
Old Jun 20, 2007 | 02:41 PM
  #56
NCCopBikeRider's Avatar
NCCopBikeRider
Great Post
Copies to my personal archives
Tahnk You again
Ride Em
Old Jul 31, 2007 | 10:32 AM
  #57
frashr's Avatar
frashr
2nd Gear
Wally- (or anyone)
Do you happen to recall; if I wanted to remove the inner-primary cover, do I have to remove the stator/rotor assembly too - or does the large circular hole in the primary cover "slip" over the top of them? I am going to replace some of the seals (shifter shaft, etc.) and don't haveanymaintenance needto remove the stator/rotor. Hope I don't have to!
Thanks,
Rob
Dallas,TX
Old Aug 12, 2007 | 06:53 AM
  #58
Wally's Avatar
Wally
I haven't done it, but if I was about to, I'd buy a service manual if I didn't already have one.
Old Sep 3, 2008 | 07:26 PM
  #59
mplecha's Avatar
mplecha
I know this is an old post, but I have to thank you for it. I'm in the process of changing the stator in my fatboy, and this (along with the manual) has been indispensable!
Old Oct 4, 2008 | 12:16 PM
  #60
Keener's Avatar
Keener
Flashr, no, you just have to remove the clutch, compesator sprocket, and chain assembly. The stator and rotor can stay attached. Although, if you have the compesator sprocket off, you might as well pull the rotor off and check it out.
