idle adjustment?????????????
Old Mar 3, 2007 | 09:22 AM
relli's Avatar
relli
Default idle adjustment?????????????
isw the idle adjustable on my 07 EGC???????????? had teh bike cut off/stall twice the other day at idle. runs great otherwise.
Old Mar 3, 2007 | 03:34 PM
Gutman's Avatar
Gutman
Default RE: idle adjustment?????????????
Idle is controlled by the ECM and isonly adjustable by the dealer. The Digital Tech will change idle speed. The idle speed should never be below 1000 rpm. A technician that knows the system well can adjust the TPS. I know the MOCO says the newTPS is non-adjustable but, voltage for correct fuel and idle should be .51vdc on all Delphi models with throttle and idle cables backed off. If not drill out press plug at lower right front corner of throttle body and adjust to correct voltage. MOCO spec is .2-1.0vdc. .51vdc is the key.
mrodff
Engine Mechanical Topics
Nov 5, 2012 04:46 PM
nkfd13
Apr 1, 2011 12:41 PM
gtojets
EVO
Feb 28, 2010 08:34 PM
wildeano
Nov 8, 2008 09:26 PM
corona1cal
General Topics/Tech Tips
Aug 1, 2008 02:45 PM
