09 Ultra
Old Aug 10, 2013 | 09:41 PM
oscarg's Avatar
oscarg
Default 09 Ultra throttle problem
My 09 has a intermittent blank spot in the throttle. It acts like the eng dies for a half sec then takes off. Then today I started the eng and it went to 2000 rpm be its self then came down in 30 secs. Any ideas??
Old Aug 10, 2013 | 11:03 PM
madhunter60's Avatar
madhunter60
had same type issue with the hiccup going down the road, ended up going to a from a pcv to a power vision tuner, the pcv fools the ecm where the power vision flashes the ecm, no issue since I changed. give Jamie a call.
Old Aug 10, 2013 | 11:09 PM
PTAG's Avatar
PTAG
The high idle is pretty much normal from time to time.
A good Dyno guy can take all the throttle lag out. At least my guy did when I had it tuned. It's pretty common on the 09's also.
I wouldn't worry about either issue on a stock tune.
Old Aug 11, 2013 | 01:10 AM
tubeman426's Avatar
tubeman426
I know a few of the throttle by wire bikes that have had problems like you describe and it was a bad throttle body. There is a wiper switch inside the throttle body (which tells the ecm the throttle position) and it can get dirty, loose contact and trick the ecm.
Old Aug 11, 2013 | 06:45 AM
oscarg's Avatar
oscarg
What did the power vision cost.
Old Aug 11, 2013 | 06:50 AM
oscarg's Avatar
oscarg
I don,t have a stock tune and have 52,000 miles on it and this is the first time I had I had a idle issue
Old Aug 11, 2013 | 06:54 AM
oscarg's Avatar
oscarg
So can the contact be cleaned or replaced or do I need a new throttle bobby? My local shop told they had two 09s waiting on throttle body's and they were on back order till sept 25.
Old Aug 11, 2013 | 07:00 AM
Iceman24's Avatar
Iceman24
Definitely check w/Fuel Moto on the PCV tune/map, but there's also a possibility tour TPS connection needs a tweak. Reach behind your intake (Left-side) & unplug the TPS connector...clean, grease (dielectric) and re-connect.
Old Aug 11, 2013 | 12:11 PM
tubeman426's Avatar
tubeman426
They are considered non serviceable. But if you are comfortable popping the clips off and removing the cover you could try cleaning the contacts with alcohol. Make sure you don't mess with the gear orientation.
Derf_
Jun 17, 2016 03:22 PM
elbohead
Jun 11, 2013 10:13 PM
conmore
Feb 2, 2012 08:17 PM
N2VSW
May 27, 2009 08:45 PM
Eric in chicago
May 12, 2009 02:07 PM
