What is the difference between the Screaming Eagle stage one and the Ventilator.
The only reason for doing this is to let the engine breath a little better and I will not be doing anything else engine wise
The stage 1 is a basic open air cleaner upgrade, round, fits behind the stock cover. The ventilator has its own cover, and from what I understand it does a better job controlling oil blow by that can come out of the breathers. The ventilator is oval. The ventilator costs quite a bit more as well, but give you a different look along with a open air cleaner. Either one is an upgrade to the stock part.
Then I hope you have a tuner ready when you change the air cleaner. You can get by with changing one or the other, but not both. Your bike will really respond to a retune!
Just installed the Fuelmoto stage 1 air cleaner, open head pipe and a power vision tuner. Went on a long trip. Blew oil all over the rt side of the bike from the AC. It kept blowing oil till I had to add oil at a QT low. Added 1/2 QT still blows oil out the breather. That style AC leaves a lot to be desired. IMO. I wished 1 had went with the heavy breather or ventilator. What a burnt on nasty mess.
Then it sounds like something else is going on in there. Warrants a second look anyway.
I have a simple setup consisting of Fuel Moto Dyno Tuned mufflers, Fuel Moto Pro Billet Stage 1 air cleaner and Nightrider FL-XiED-10 kit. I have no issues whatsoever. Just sayin'...
