does any one happen to know what code u 1040 may be
i 'm thinking it's my problem with antilock brake light staying on
but i checked search and found some codes but not this one .
anyone know what this code is? appreciate any input before i go to
the dealer and have them tell me a thousand dollars later.
i do appreciate the help .but that particular code
isn't it any of those.guess i will have to keep on
looking.
that is the only code in the whole system
everything else says none .i tried to clear it
so it must be current code.thank you
DTC U1040 indicates that the ABS module is not capable
of sending its state of health message. ( and this makes the ABS Light not flash ) check connections on the Module ...all fuses ...
I have the 09 electrical manual for the touring line and its not in there. It mentions several U codes but all appear to be serial data codes. I found this on another forum.
"U1040 indicates no serial data communication with ABS module."
thank you gentleman
i think we may be getting somewhere now
i did check fuse and all the wires i could reach
nothing obvious .so i will get behind the lower fairing and see what
that looks like i did read where they zip tie the wires tight
and a hard brake or sharp turn may stress these wires where they
are connected to the steering neck.many thanks to all
will let you know what happens
