exhaust help!!!!
Old Aug 16, 2013 | 08:05 PM
Tee Bagger's Avatar
Tee Bagger
Default exhaust help!!!!
I just bought a set of lightly used Vance and hines tru duals for my 2011 street glide. The guy I bought them from assured me they would fit my bike. When I got home I noticed the o2 bungs are up near the head..
And the mounting looks different. I found a slip in the bottom of the box saying 2009 road king. Looks like 2009 has a different p/n than 2010 and newer. I got a smokin deal on these pipes.... can I make them work? Can I reroute the 02 sensors??? Maybe fab up a mounting bracket??? Or are the pipes all together different??
Thanks in advance!!!!
Old Aug 16, 2013 | 08:20 PM
Roadie13's Avatar
Roadie13
If I remember correctly, and someone will certainly chime in if I'm wrong, the 09s had the larger O2 sensors in the header near the exhaust outlet. The 10s and up have the 12mm sensors in the header just upstream of the cats. You should be able to plug the 18mm holes and they sell a rivet type tool which will form new holes after drilling a pilot hole.
Old Aug 16, 2013 | 08:46 PM
Tee Bagger's Avatar
Tee Bagger
I see Krome Werks sells exhaust that fits 09 and newer...but it says 10 and newer requires there $30 kit...wire extensions and 12mm to 18mm bung adapters.... maybe that will work??
Old Aug 17, 2013 | 05:00 AM
Tee Bagger's Avatar
Tee Bagger
Any input?? Extend the wires?? Weld in new bungs??
Old Aug 17, 2013 | 05:39 AM
NascarGuy's Avatar
NascarGuy
If your set on using the pipes you'll have to extend the wires and get some adapters like the ones in my link below. Hope this helps.
https://www.denniskirk.com/4406482.s...Fah9OgodoVkAyg
Old Aug 17, 2013 | 11:36 AM
skydude426's Avatar
skydude426
Namz Custom Cycle Products sells a kit with 24" O2 sensors extensions and 18mm to 12mm bung adapters.
www.namzcustomcycleproducts.com
Scguardian
Sep 17, 2017 08:04 PM
TOUCHNGO
2014-2024 Touring Models
Aug 10, 2015 05:09 PM
hall1836
Jan 15, 2014 11:07 AM
chaz mcnasty
Jan 2, 2013 09:10 PM
En4sir98
Nov 10, 2012 05:57 PM
