Bike is throwing code B1006, any thoughts?
Old Aug 25, 2013 | 02:48 PM
TMOUT's Avatar
TMOUT
Default Bike is throwing code B1006, any thoughts?
2011 Limited is throwing code B1006 on the sp & t sector of the diagnose function. Did the clear thing, ran the bike, code came back.
Translates into " Accessory line over voltage ", has anybody ever seen or heard of this code? Not quite sure where to start chasing this one............
Old Aug 25, 2013 | 03:20 PM
Bingee's Avatar
Bingee
Are you putting it on a battery charger? If so it's likely the charger is bad. If not, have your bikes charging system checked out. It could be faulty regulator.
Old Aug 25, 2013 | 04:12 PM
pswomack's Avatar
pswomack
Have you installed any external Auxillary lights? IE: Saddle bag spoilers w/lights, luggage rack w/light, or any device that connects to the auxillary plugs?......If so you may want to check there first. Something is putting more power where it shouldn't be, also like Bingee said, check the charging system, could be a voltage regulator or a stator.
Old Aug 25, 2013 | 10:59 PM
TMOUT's Avatar
TMOUT
Thanks for the input guys, haven't added anything electrical lately, and nothing to the acc. switch/plugs. Think it might be time to take it to the dealer.........ugh.
Old Aug 28, 2013 | 03:50 PM
TMOUT's Avatar
TMOUT
UPDATE...........
Got it checked over at the dealer, turns out it's the Badlands load equalizer for the led turn signals thats spiking when the ignition is turned on. The ECM is set to throw a code whenever it sees 16 volts or over for 5 seconds, apparently the Badlands Equalizer does this when it's first powered up. So it's not dangerous, & won't harm anything. Just wanted to pass that along in case anyone else installs the LED signals with a Badlands EQ.
Old Aug 29, 2013 | 01:11 AM
DesertH-D's Avatar
DesertH-D
TMOUT - No disrespect to your dealer, but he is incorrect on the description. A load eq is a passive device. It sinks current, only when power is applied to it. It cannot generate voltage. Something else is going on. It might be something to do with the load eq, but I know for sure it's not making 16V! I would suggest calling or emailing Dan at Badlands. I have worked with him on several issues, he always has had an answer.
Old Aug 29, 2013 | 06:06 AM
Assegai's Avatar
Assegai
The regulator's job is to rectify/regulate the stator's output. The code is telling u that the supply voltage when the bike is running is spiking. With the engine running@ 2k put a VOM across the battery, should be about 14.5 vdc. Strongly suspect the Regulator or the ground.
Old Aug 29, 2013 | 06:38 AM
'05Train's Avatar
'05Train
FWIW, I had the exact same problem with the exact same code on my bike. I was using a Custom Dynamics load equalizer/line conditioner. With it connected, it threw the code. Disconnected, no code.
techmanrod
Oct 16, 2019 04:29 PM
Lowell64
Apr 30, 2016 05:36 PM
skrody
Electrical/Lighting/Alarm
30
Sep 3, 2015 06:19 AM
WrenchinRider
Aug 10, 2013 08:28 PM
Chips
Oct 16, 2007 06:46 PM
