2014 103 Cam
Old Aug 26, 2013 | 04:13 PM
madmustang4's Avatar
madmustang4
Default 2014 103 Cam
The local dealer says the duration on the new 103 cam is pretty much the same as the SE255. If thats the case, why not just go with the 255 cam rather than a new one?
Old Aug 26, 2013 | 04:15 PM
Deer Stalker's Avatar
Deer Stalker
Perhaps because they can't claim it's new?
Old Aug 26, 2013 | 05:22 PM
euchre98's Avatar
euchre98
Its close to a 255 but not quite...
Old Aug 26, 2013 | 05:26 PM
buggin02's Avatar
buggin02
Because if they told you it was the exact same as the 255. then you would rightfully conclude that you would get the same performance by just putting a 255 in your current bike.
If you keep your old bike then they aren't selling you a new one.
Old Aug 26, 2013 | 07:08 PM
1Canuck's Avatar
1Canuck
Plus it eliminates a legal issue in explaining why the 2014 needed it but the 2013 did not. same as the new (again) improved compensator. They are fixing things after the fact but cannot find themselves in a legal bind by admitting there was a problem
Old Aug 26, 2013 | 07:56 PM
GPHDXLC's Avatar
GPHDXLC
According to the sales manger at ******* Mi Harley, he said the new HO 103 cam is a lot like the 255 with a little 204 mixed in for better passing power.
Old Aug 26, 2013 | 08:09 PM
EdandGrace's Avatar
EdandGrace
So then it would make sense to label it and make it available. I would consider it.
Old Aug 26, 2013 | 08:39 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Why? It would still be a EPA cam and top dollar with the HD logo on it....Better and possibly cheaper cams are available that can be tuned a lot better then the HD ones.....
Old Aug 26, 2013 | 10:05 PM
CT-Bagger's Avatar
CT-Bagger
The Motor Company is expert at making you think you need something from them when in most cases better products and performance is available from aftermarket companies.
Why now after years of the 103 being introduced is the new improved cammed up version so much better?
Couldn't these idiots over there have put a better cam profile in these anemic 103's from the start?
Oh wait ... These have liquid cooled exhaust valve ports.
I guess we should all order new heads?
Old Aug 27, 2013 | 12:33 AM
ke5rbd's Avatar
ke5rbd
Intake Open BTDC___Closes ABDC____Duration____Intake Lift___Center line
Stock_____-12________30__________198________.484_________111
2014 TC____3_________30__________213________????_______ _103.5
SE 255_____6_________25__________211________.556_____ ____99.5
Exh___Opens BBDC___closes ATDC___Duration_____Exh Lift_____Center Line
Stock_____38__________4__________222________.484__ ________107
2014 TC___43_________10__________233________????_______ ___106.5
Se 255____48__________7__________235________.556_____ _____110.5
________________Cam center line__________________Degrees Advance__________overlap°
Stock________________109__________________________ __-2___________________-8°________
2014 TC_____________105____________________________1.5_ __________________13_________
Se 255_______________105____________________________5 .5__________________13_________
Hope all this is legible. Don't know the lift, but higher than stock. Probably .555"
