Need a lifeline for No Start
Old Oct 16, 2013 | 08:51 PM
  #51
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
Yeah I'm pretty sure it was freak failure of the injectors, unique to my dumb *** running dry of fuel more than once. I just noticed it bad yesterday going to lunch. Today I dedicated to building a batch of chrome fans for a bunch of people who have been waiting patiently. If I got time tomorrow after packaging, I may pull the injectors and take them to one of the local shops to see If I can get it matched up. Maybe even dissected to see what the problem is/was. Meanwhile the new OEMs are available on Ebay for $50 a set. I don't have any issue with the OEM injectors, just checking to see whats out there since I'm going to replace them anyway. It really isn't a topic you run across very often, unless talking about bumping up for more fuel delivery on a performance build.
Old Oct 16, 2013 | 09:08 PM
  #52
Pelonz's Avatar
Pelonz
You may want to consider SE Injectors. I believe they have a different spray pattern for combustion chamber cooling. Then again that might just reduce your mileage.
Old Oct 18, 2013 | 03:25 PM
  #53
WARDSPARTSWERKS
I found a local injection specialist shop, the MGR looked them up and said they were a dedicated injector, not generic, but by chance he had some from a lot purchase, exact HD part number. $45 each, I got the new ones but left the old ones for assessment/repair/service, hopefully they will have some kind of idea what's up with them, after they get dissected. The take away at this point is don't waste any energy looking for a generic replacement. I'm not going to count my chickens till I get it all back together and running.
Old Oct 18, 2013 | 08:29 PM
  #54
WARDSPARTSWERKS
Let the ball busting begin. When I was trouble shooting the original problem, I used a noid light to verify signal to the injectors, I only checked the rear because that's where I started and I had signal, no need to check the front. Well apparently the pins on the noid light were slightly larger than the pins on the injector and the sprung the contacts on the injector connector. I pulled the connector apart straightened up the socket pins with a scribe, put it all back together and it works fine. Oh yeah, the injector shop called and my original injectors are ready for pick up, guess I got a spare set now. Thanks again to all.
Old Oct 18, 2013 | 08:36 PM
  #55
Pelonz's Avatar
Pelonz
Happens to the best of us
Old Oct 18, 2013 | 08:38 PM
  #56
my67pnycar's Avatar
my67pnycar
Glad you got it figured out man, sorry to think your last post was kinda funny after all the chit you went thru.
throwbackjack
Jul 17, 2019 04:19 PM
old cat
May 30, 2019 05:19 PM
Goupner
Jan 19, 2015 12:33 PM
alottamiles
General Topics/Tech Tips
Nov 27, 2014 12:40 AM
hawg02
Exhaust System Topics
May 27, 2007 05:45 AM
