Was this bagger wobble or something else??
Old Aug 30, 2013 | 12:24 PM
Biker John's Avatar
Biker John
Default Ditto Tru-Trac
Originally Posted by tbone108
Hello Goofy
Its inherent in the design of that bike. I am thinking of getting one about the same age as a second bike. If I were you I would fit tru-track on the front and rear and just enjoy the bike for what it is.
tbone.
My 2002 EG had that problem...added a tru-trac and some good Dulop E3 tires and a lot better. I like the other tires Avon & Metzler but there's just some thin funny about those euro-type tires gotta watch PSI all the time or they feel soft to me when cornering...maybe just me?
Old Aug 30, 2013 | 12:25 PM
btsom's Avatar
btsom
AND unless you have a recently CALIBRATED air gauge add a couple psi to be on the safe side in case it might read a little higher than actual pressure. A little extra pressure is far safer than a little too low.
Old Aug 30, 2013 | 12:48 PM
mkguitar's Avatar
mkguitar
thinking with those tires, this may be the correct frame brace for that model, about $150:
mike
Old Aug 30, 2013 | 01:18 PM
grbrown's Avatar
grbrown
Wink
No it's not just you! I have lost count of how many times I post on HDF that when using non-stock tyres we should always check the manufacturer's website. Avon routinely recommend higher pressures than the stock factory tyres. Cobras (Avon's latest Harley friendly tyre) for your bike should be 38F/44R, solo.
Avon are indeed European, in fact British old chap, owned by Cooper Tires. So you can buy the best AND buy American!
Old Aug 30, 2013 | 05:11 PM
GoofySB's Avatar
GoofySB
Originally Posted by grbrown
Goofy, you can ask our advice and ignore it if you wish, just don't expect to solve your problem if you do! Get yourself a new set of tyres and use the correct pressures, as per the manufacturer's website.
Guys, I ordered a Avon Cobra for the front about noon today. Supposed to be here by Tuesday, we will see. My rear Cobra is a year old with 6,000 miles; it should be ok for a while. I'll have the trueness checked by my local Indy when he mounts the front for me.
Graham, I didn't notice in post 7 you were listing pressures for a Venom. My rear is actually a Cobra and sidewall says 40 psi max. I looked here http://http://avon-tyres.co.uk/motorcycle/cobra and cannot find a max pressure, so...
Goofy,
PS, when E3's come out in wide whitewall, I'd love to try a set. Until then, choices in WW are slim.
Old Aug 30, 2013 | 05:27 PM
grbrown's Avatar
grbrown
Cool
Originally Posted by GoofySB
Ordered a Avon Cobra for the front about noon today. Supposed to be here by Tuesday, we will see. My rear Cobra is a year old with 6,000 miles; it should be ok for a while. I'll have the trueness checked by my local Indy when he mounts the front for me.
Are you saying I should exceed the sidewall maximum air pressures?
Goofy,
PS when E3's come out in wide white wall, I'd love to try a set. Until then, choices in WW are slim.
I'm saying check Avon's website! For your bike they recommend:
FLHR / I / CI Road King / Classic (1994 - 2003)
Front Tyre Cobra
Pressure front:
2.6 bar (38psi)
Front size: MT90B16 74H (also WW)
Rear Tyre Cobra
Pressure rear:
3.0 bar (44psi)
Rear size: MT90B16 74H or 140/90B16 77H (also WW)
Ignore what it says on the sidewall, go by the manufacturer's stated recommendation, above. The figures on the sidewall are a guide only. Avon give general guidelines here, from which you will see that you can use pressures from 38-43 front, 44-50 rear.
You can also find useful info from their UK website, which is where I got the data above.
Old Aug 30, 2013 | 05:37 PM
baust55's Avatar
baust55
Invest a few extra $$bucks$$ for a quality air gage ,check your air pressure frequently .
You will find that not only will your bike perform and handle better / safer with properly inflated tires they will last much longer ,many more miles .
I have e3s I run 38lb front 42lb rear .
Works for me .
I ran 40 and 44 with the metzlers on my shovel
Old Aug 30, 2013 | 05:40 PM
GoofySB's Avatar
GoofySB
See edits to post 15
GSB
Old Aug 30, 2013 | 05:44 PM
GoofySB's Avatar
GoofySB
Graham, got it!! http://www.avon-tyres.co.uk/motorbik...d-king-classic
Will bookmark or print out the general section for Cobra pressures.
Thanks a bunch
GSB
Old Aug 30, 2013 | 06:11 PM
GoofySB's Avatar
GoofySB
LOL, funny funny. Wonder how we ever survived 6,000 miles on those tires. I ain't Goofy for nutin!! BTW already got one
mike
