$6 Fix for Excessive Vibration ('12 SG)
Old Sep 5, 2013 | 05:09 PM
John Bakker's Avatar
John Bakker
Default $6 Fix for Excessive Vibration ('12 SG)
Lately my 2012 Street Glide with 16,00km (10,000mi.) seemed to be vibrating more than normal. I'd feel this particularly thru the bars and footboards. It also didn't run as smoothly at highway speeds. This was a gradual thing that snuck up on me until I decided to investigate. I made sure that no parts of the exhaust were touching the frame. Then I remembered what fixed the same thing on my old Evo.
I looked at the rubber supports for the muffler brackets (under the bags). After loosening off the mufflers I noticed that the rubber slot was quite worn, especially on the right side. A trip to my friendly parts guy and 10 minutes installing new ones and now my SG feels normal again. I knew right away I was off to a good start when I pulled on the front brake in the driveway and the vibes transmitted back to me were cut in half.
I'm not saying this is a cure for everyone's vibration issues, but it's worth trying, that's for sure.
John
Old Sep 5, 2013 | 05:21 PM
Scorpion07's Avatar
Scorpion07
I did the same last year. Same results. Made my 07 Ulta feel like a brand spankin new bike. Kinda.
It's amazing how "some" little things can make a big difference.
Old Sep 5, 2013 | 06:24 PM
bent trix's Avatar
bent trix
Yep - Yep! Did the same thing to my 04 with 4500 miles on it.
Old Sep 5, 2013 | 06:25 PM
jg4660's Avatar
jg4660
Thanks for the info...its nice to see a post with a problem and a solution. I'll keep this one in mind.
JG
Old Sep 5, 2013 | 06:46 PM
davey019's Avatar
davey019
You would think these should last longer
Old Sep 5, 2013 | 07:02 PM
Notgrownup's Avatar
Notgrownup
I change mine about 1 a year or every 2 years...
Old Sep 5, 2013 | 07:05 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Now if you could come up with a fix -
For "Bad Vibes" coming from in the house!
Old Sep 5, 2013 | 07:46 PM
williamfrog's Avatar
williamfrog
Replaced mine 2 times in 40,000 mi. Mine started to make noise that would go away if you put your foot on muffler.
Old Sep 5, 2013 | 08:00 PM
skratch's Avatar
skratch
what are you talking about? i saw two of them in your sig pic. pick one and go. no more 'bad vibes'
Old Sep 5, 2013 | 08:49 PM
dawg's Avatar
dawg
Flip upside down, replace with HD or replace with polyurethane
