Sacrifice comfort for safety. Heat is the biggest safety problem with tires and the lower the pressure you run, the greater the heat generated. Combine that with high pavement temps in summer and there isn't a lot of safety margin. Run the max cold pressure shown on the sidewall (or a little more to allow for gauge error) and take the ride quality that delivers as a fact of life.
2006 Roadglide with Commander II Front 36 PSI. Over 20,000 miles with zero cupping. Will change tomorrow with same tire. Rear at 40 PSI and get 13,000 to 14,000 miles. Some two up riding but mostly solo. Love my Michelins.
