Front suspension improvement ?
Old Sep 8, 2013 | 03:54 PM
1HD2NV's Avatar
1HD2NV
Default Front suspension improvement ?
Taking front end apart to replace a lower leg and wondering if I should upgrade anything? Have heard a lot on here about the Gold Tech emulators.
Old Sep 8, 2013 | 04:00 PM
mainboom150's Avatar
mainboom150
progressive fronts or the Harley deluxe springs for the front
Old Sep 8, 2013 | 04:07 PM
ynots's Avatar
ynots
It would be a great time to do it. I put progressive springs on my fxd and it cured the excessive diving and clunk I was getting in my front end. Maybe not the best option but for the 60.00 it cost me it was a very worthwhile investment.
Old Sep 8, 2013 | 05:41 PM
djl's Avatar
djl
The recommended Race Tech springs, the GV emulators, the right preload and oil and you will not believe the difference. Drain the oil in the OEM rear shocks and replace with 7W. I am assuming you can drain the OEM rear shocks on the '10 models like you can on the early models.
Old Sep 8, 2013 | 05:54 PM
1HD2NV's Avatar
1HD2NV
Some quick research shows plenty of options. Just need to figure out what is best. None are overly expensive so that is not a concern in the decision
Progessive Monotubes
HD Premiun Ride cartridge
Race Tech Emulators
Ricor Intiminators
Have Ohlins 3-3 from Howard on the back already.
Old Sep 8, 2013 | 06:31 PM
jvvjvv's Avatar
jvvjvv
https://www.hdforums.com/forum/touri...rk-better.html
lots of reading....it will keep you busy for a while.....
great set up.
Old Sep 8, 2013 | 11:38 PM
0ldhippie's Avatar
0ldhippie
I have had Progressive springs, Progressive springs with gold valves, Racetech springs with gold valves and race-tech springs with Ricor valves. Both the race-tech setups are very good, with the Ricors winning out. Both the valves take a little tuning but well worth it.
Old Sep 9, 2013 | 06:09 AM
mstng5point0's Avatar
mstng5point0
Ive been looking at the Progressive monotube cartridge kit. Anyone used it is it worth the money over a drop in kit and thicker oil?
Old Sep 9, 2013 | 08:21 AM
1HD2NV's Avatar
1HD2NV
Still researching but am leaning towards Race Tech springs with the Ricor Intiminators. Hoping fabrik8r/WardsPartsWerks is still doing the Ricor upgrade. Will be PM'ing him soon. Only concern for me is I come in at close to 300 lbs which calls for a 1.167 and the largest they offer are 1.0. Not sure if I should look at other manufactures or if the 1.0 will work OK.
Old Sep 9, 2013 | 10:40 AM
fabrik8r's Avatar
fabrik8r
Got you covered, PM me when you're ready. Traxxion will have what you need, or make it, you'll have to call and order them, make sure to specify single rate and don't let them talk you into a different rate. I would recommend 1.15KG.
