wrapping the cat
Old Sep 10, 2013 | 11:24 AM
hardheaded's Avatar
hardheaded
Default wrapping the cat
anyone ever try wrapping the cat converter with that pipe wrap they sell ? friend of mine just bought a left over 13 and can't stand the heat, but has the extended warrenty and doesn't want to fool with it. i told him i removed my cat, warrenty or not. just wondering if anyone has tried this. don't want to melt down the converter.
Old Sep 10, 2013 | 11:53 AM
GARY DYER's Avatar
GARY DYER
I've never seen anyone ask this question either. Would like to know if there would be a problem.
Old Sep 10, 2013 | 12:47 PM
Ovaltine Jenkins's Avatar
Ovaltine Jenkins
The excessive heat due to the wrap not allowing it to radiate/convect away will result in metal fatigue and, possibly, breakage at a later date. The wrap also tends to hold in moisture.
Old Sep 10, 2013 | 12:52 PM
lakedrum03's Avatar
lakedrum03
Just my opinion, but I would bet that wrapping the pipes would also void the warranty. I don't know that to be fact, but just seems like something they would put in their weasel clause of the warranty.
+1 on removing the cat. Cutting the "window" and rewelding it is the way to go.
Old Sep 10, 2013 | 12:58 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Tell your friend, to go on E-bay and buy a set of de-catted pipes, and keep his stock ones for just in case he needs to go back to the cats for any reason.
I got a set of catless pipes, tig welded back together with stainless rod on E-bay for $135 shipping included. Took me about 1 1/2 hours to change them out..... and that was taking my time.
Old Sep 10, 2013 | 01:11 PM
hardheaded's Avatar
hardheaded
we were not talking about wrapping the entire pipe ,just the cat. i think the pipe is stainless where the cat is located,so heat shouldn't be an issue. i was wonder about melting the cat. i drilled my cat out and it worked very well, clean as can be, nothing left inside.
Old Sep 10, 2013 | 01:48 PM
08EGUltra's Avatar
08EGUltra
wrapped the wife's tri glide and it did not make enough differnace to ehlp her enjoy the ride. Got the cat out of there and things are better, still heat but not 2nd degree burn hot.
Old Sep 10, 2013 | 03:18 PM
GARY DYER's Avatar
GARY DYER
A guy that works at my dealer has his pipes wrapped and says it works great. I see a lot of riders wrapping their pipes. I would like to do it to mine if it didn't look so ugly.
Old Sep 10, 2013 | 03:34 PM
shooter5074
You can put your heat shields on top of the wrap, if you do a nice clean job and don't get it to thick. You can even get the wrap in a few different colors so it doesn't stand out in the bare spots so bad.
Old Sep 10, 2013 | 03:49 PM
0ldhippie's Avatar
0ldhippie
I wrapped my stock '09 non-cat header and didn't think it helped much but it was also a light wrap. I did a proper wrap on the Fullsack header I recently installed and there is almost no exhaust heat. The sheilds fit fine with wrap. Converters are designed to run hot, they don't melt.
torchmaster
Jul 22, 2015 07:50 PM
mikeo33y
Apr 21, 2014 10:10 AM
flashracer
Oct 8, 2011 05:37 PM
Valkyrie
Aug 21, 2011 12:46 AM
dirtpan
Exhaust System Topics
17
Mar 7, 2008 09:17 PM
