Fuse block 2008 classic
Old Sep 11, 2013 | 05:20 PM
Greg The Hammer's Avatar
Greg The Hammer
Stage I
Default Fuse block 2008 classic
I need information on removing the left fuse block cover. The method o remove is not obvious and I don't want to screw it up. Looking to access fuse block on a 2008 Electra Glide Classuc
Old Sep 11, 2013 | 06:00 PM
dawg's Avatar
dawg
Welcome to the forum. The fuse block cover should only be held on with a snap clip. I believe it's on the bottom and then you lift up and off. If you haven't figured out the actual left side cover, that is held on with three pop in plugs and you just pop it off.
Old Sep 11, 2013 | 06:28 PM
SH_01FXDWG's Avatar
SH_01FXDWG
If its like my 06 electraglide. Pull left side panel off as described above. Next, grab fuse block and pull AWAY from frame. If its like mine, the block just slides on and off some tabs on the frame. After that you can probably figure it out. The cover just snaps over the block.
nascar7613
Aug 6, 2013 10:48 AM
TCC
Oct 21, 2009 08:37 AM
tomccc
Sep 26, 2009 11:25 PM
Dispatch
Dec 19, 2008 03:07 PM
BigJohn
Oct 16, 2008 01:32 AM
