New SG rear light upgrade...
Old Sep 15, 2013 | 11:30 AM
mistersandman202's Avatar
mistersandman202
Default New SG rear light upgrade...
I need to add more light to my new 2014 SG which has the new double turn/brake lights. I miss the big "bright-*** light" I had on my '09 SG which flashed to alert sleepy drivers behind me. Does anybody have any ideas?
Old Sep 15, 2013 | 11:32 AM
UkCatsHarley's Avatar
UkCatsHarley
What are the new double turn lights?
And I agree nothing beats a BAL.
Old Sep 15, 2013 | 11:45 AM
hellbob37's Avatar
hellbob37
Get the module that turns the lower running light into a brake light. Thats about all I've found
Old Sep 15, 2013 | 12:01 PM
bobgv's Avatar
bobgv
Also get the custom dynamic LEDs, they are much brighter than those stock bulbs. If you go these route you will need a load equalizer as well. Biketronics has a good equalizer that's plug and play and has a lifetime warranty.
Old Sep 15, 2013 | 12:43 PM
Fatboy Brian's Avatar
Fatboy Brian
I have them and they are a lot brighter. A friend that I was riding with the other day thought I was riding the brakes they are so bright.
Old Sep 15, 2013 | 02:07 PM
flhxkiller's Avatar
flhxkiller
I'd wait and see what the MOCO comes up with before making a change. Those who are waiting for the removable tourpak kit will need lights in the fascia to replace the turn signals in the tourpak. I'm sure something is in the works to be released in the next catalog.
Old Sep 15, 2013 | 03:15 PM
jasnusc's Avatar
jasnusc
This is EXACTLY what Im going through. I had an 09 SG w/ BAL and now have a 14 SGS on order. I saw the custom dynamics led's but didnt know I needed an equalizer? Thought about adding the CVO rear fascia and LED's with the stock fender.
Can someone confirm we would need an equilizer? Some of the new 14's come with LED's are you sure we still need that?
Will the CVO rear fascia fit on the stock fender and if so has anybody done this?
Old Sep 15, 2013 | 03:30 PM
2goldens's Avatar
2goldens
Along the same lines, I'd like to simply add a plug & play wiring harness and LEDs for the tail light and the rear signal lights that turns them all into brake/running lights.
Anyone have a MOCO part number yet for the '14 SG?
acchd's Avatar
acchd
You could install a '09 SG rear fender and then be able to use BAL.
Old Sep 15, 2013 | 06:45 PM
dh2683's Avatar
dh2683
Attachment 333442
Look at HD Part # 68000119
