road king handle bars
The stock handle bars were bad, The Heritage were an improvement. The good thing about the heritages were they were cheap and did not require cable or wiring changes. The bad thing is the wrist angle sucked. There to narrow causing a pain between the shoulder blades.
After a lot of measurements and research I ended up with the Wildones 12.5 apes. They did require the wiring to be extended new +6 clutch cable and +6 Brake line (Non- ABS)
The handle bars are now about 95% Perfect, After riding with these for two years I feel the 14 inch apes would have been the 100% choice.
The easiest (simplest) way to figure out what you need is to block the bike up so you can sit on it in your normal riding position. Sit on it put your feet and *** were you normally ride. Close you eyes and put you hands out to where they feel most comfortable, the open your eyes and see were your hands are in relation to your existing handle bars and note the difference.
The first thing your going to notice is your hands are going 4 to 6 inches above you stock handle bars and more than likely your grip is going to be wider, somewhere around 30 to 34 inches.
One other thing to note, not all handle bar manufactures measure the handle bars the same way. So you have to measure you handle bars the same way they measure theirs to get the actual difference.
One final note, The handle bars should be the last modification to your comfort. You want to get the lower half of your body were it comfortable. Feet and seat before you do the handle bars. If you change the feet and seat after you change the handlebar they my not be in the right position after the change.
Can I buy all extensions and can I do it or is it a dealer job?
About how much will it cost me to go your route?
Do you have cruise?
Hap
Thanks
The biggest part of the job is the wiring. This is due to having to take the plugs off the ends of all the handle bar wiring harness. Lot of pictured and drawing and good diagram of where all the colors go into the harness plugs. The next trick is getting all the wire through the handle bars. once the wiring is through all the handle bars you have to put the harness plugs back on.
The next task is the clutch cable. the manual state to remove the exhaust. But I did t with just loosening the heat shield. You going to loose some oil. but not a hard job.
The front brake lines are not hard. BUT, Mine is a non-ABS bike. If you have ABS Brakes a trip to the dealer may be required to have them bleed the brakes.
Cost Is a different story. I think most dealers charge between 4 to 6 hours for the job. So if you do it yourself your 4 to 6 hundred dollars ahead.
I picked up my bars 2nd hand for 100.00 (Like New) extension wire about $50.00, Don't Skimp Here. I also got the Stainless Steel clear coated clutch and brake lines, expensive. Black line are cheaper.
Parts wise your going to be between $500.00 and $700.00 Dollars
This is not a cheap job so make sure you have the right bars picked. You don't want to do this job twice.
Speaking of doing it twice, I will probably be doing the job again this winter. I want to add the radio control switch to the controls. I have the switches but I basically have to do the same work as replacing the handle bars to install the switches and run the wires. I may consider going to the 14 inch apes then.
Thanks
