2014 Speaker Access Question
To begin, I cannot look this up in the manual as I don't have it yet. I ordered the 2014 Service Manual but shipping ETA isn't till 9/23 so the earliest I probably will get it is end of month. Not wanting to wait two weeks, I would like to install these right away, hence the question due to no manual yet.
Question is I've opened up the fairing and checked out the new plastic enclosure of the speaker setup. Not sure how to get it off without removing every screw so looking to see if anyone has opened theirs up yet or has a manual already and can look this up.
I was told the speaker mount on the fairing can accept 6.5" speakers without an adapter but not a big deal if an adapter is needed since I still have the 5.25" to 6.5" adapter rings from the 2013 install.
Can't see it working with an adapter. The speakers are in a sealed housing now. An adapter might push them out too far where the outer fairing might not fit (but can't say for sure)
It is nice to actually hear Bass on a motorcycle. That being said, I also ordered the amp. Hoping to save up and install the bag lid speakers this winter.
What do you think of the new Boom 6.5" speakers vs. the factory 5.25" speakers? Is the sound better, louder, crisper? Do the speakers put out significantly more sound or in your opinion does it sound like a minor improvement in volume?
Did you install your 6.5" into the stock mounts or was there an adapter required. Looking at the Boom speaker pics online doesn't look like there is an adapter included that they might just mount directly to the fairing. Would that be correct? Don't really want to tear down the fairing and enclosure only to find that HD changed this setup enough to make the Polks I have not easily installed and may be forced to buy the Boom speakers.
Any info will help and is most appreciated. Thanks for checking in and commenting on my question.
The boom speakers mount right on to the white enclosure. The grills screw on to the inner fairing.
The Polks might mount right in (had to say, I should have tried a set of 6.5's I had in the garage) with a slight modification.
The speaker housing is also used as a mount for the inner fairing, I assume that is why there are so many mounting screws/bolts.
The booms add some bass, and are cleaner when the volume is cranked. I still find myself turning the volume to "11" sometimes.
I am still ordering the 4 channel amp but quite a back order on them right now. Winter project will be speakers in bag lids or lower fairings (not sure which ones) Wishing the bag lid speakers were 6x9's instead of 5x7's
Are the torque specs the same? Does the windshield come off the same way? I know there are two less screws but thats about it.
Thanks
Thanks
Windshield comes off the same way. Take the 3 screws out, remove windshield. Put center screw back in by hand a few turns (so outer fairing wont drop when taking out other screws) Remove the screws on the back side of inner fairing. Hold the fairing in your hand and remove the center screw for windshield. (good idea to put a blanket or couple towels over the front fender)
Gonna have to start saving!
Leaves are falling, less than a month of riding left, hope the parts come in soon.
