2014 Limited Cooling Question - Why Regular Coolant?
Old Sep 20, 2013 | 09:24 AM
Ventoso's Avatar
Ventoso
Default 2014 Limited Cooling Question - Why Regular Coolant?
My '14 limited has now about 1K on it, and this weekend I will be doing the 1K service on it.....
It has never leaked any coolant, and the fans do run for 15 to 30 seconds after shutdown after a hot run. Fantastic bike, no complaints, so far, my Best HD ever.
My question is, Why the hell do they use regular coolant for such a hot and limited application? Why don't we run Evans Waterless coolant in them?
The system pressure would be near zero, it won't cavitate, won't corrode, compatible with all metals, won't boil, pretty much can't boil over, won't freeze, your cat can drink it and won't die, and it never needs to be changed?
DEX coolant boils at 265F at sea level with 15PSI pressure on it, the Evans NPG+ boils at 350F at Sea Level with ZERO pressure in the system. It CANT boil over, period.
Sure its $40 a gallon, but for only a couple pints of fluid, am I (or HD!) missing something here???
No I do not work for them, I am an engineer, I will be looking into this more, I think someone missed the bus to work at HD.
http://www.evanscooling.com/
Old Sep 20, 2013 | 09:37 AM
hillbillywhisperer's Avatar
hillbillywhisperer
Newbie and have never owned a Harley. Waiting for the bugs to be worked out on the 14's and have thought of this same thing. Run this in my ATV and Ranger. Is there a warranty issue maybe?
Old Sep 20, 2013 | 09:39 AM
hillbillywhisperer
Newbie f up. deleted
Griff012FLHX's Avatar
Griff012FLHX
Dam good question....
Old Sep 20, 2013 | 09:46 AM
bigfish_Oh's Avatar
bigfish_Oh
I did not know their was such a thing, sounds good to me.
but picture this.... HD's solution is to recall and refill with this and then relabel it at $70. a gallon and specify the specs(for aftermarket) and a yearly change interval or warranty void. then more owners will complain.
Old Sep 20, 2013 | 10:02 AM
sat4314's Avatar
sat4314
subscribed. since it will be changed at the 5k service. Don't see a reason we can not run it. No different that others going to different makes of oil. Curious to see some others thoughts on this one. Good question!!
Old Sep 20, 2013 | 10:07 AM
edpnjax's Avatar
edpnjax
Once again, as with any fluids....
As long as it meets or exceeds HD's specs, they can't tell you what brand of fluid to run, unless they want to provide it for free. They also cannot void your warranty for running a Non-HD brand as long as it meets or exceeds their specs. It's a federal law, read up on it.
That said, I would save all receipts to prove what I did and what I used in case there is a warranty issue and they try to deny the claim.
Old Sep 20, 2013 | 10:55 AM
Jerry1834's Avatar
Jerry1834
Interesting.....keep us posted
Old Sep 20, 2013 | 11:15 AM
journeyman's Avatar
journeyman
Seems to me they should have put oil in the radiator.
That way when you go to the Dealer and say it's leaking oil.
They can say ...... It's normal it's a Haaarley !
Old Sep 20, 2013 | 11:20 AM
vizcarmb's Avatar
vizcarmb
cause you know they have been using the same type of coolant on cars for many years with no issues.
