tire life
Old Sep 23, 2013 | 04:10 PM
rbm33's Avatar
rbm33
Default tire life
this had probably been covered a thousand times but what kind of life can I expect out of a factory front tire on a street glide.
the reason I ask is that if I remove my hands from the bar for just a second it starts vibrating slightly and quickly grows in to a full blown head shake,.
thanks in advance
Old Sep 23, 2013 | 04:13 PM
FXDWG12's Avatar
FXDWG12
Sounds more like you need to check your steering fallaway? Tire wear will depend on a lot of things. What does the tread look like?
Also check your air pressure.
Old Sep 23, 2013 | 04:40 PM
rbm33's Avatar
rbm33
tread doesn't look great but it doesn't look horrible either. bike has about 7k miles on it
Old Sep 23, 2013 | 05:09 PM
b17467's Avatar
b17467
I got 22,000 out of my first front and 21 out of my second. Probably should have replaced them sooner. Both times I had the same thing you are talking about at low speeds, 30 or so. As soon as I replaced the tire it stopped. Both were Harley Dunlop's. I've got a Commander II on now, as I'm getting great results with the rear I put on 16,000 ago.
Old Sep 23, 2013 | 05:14 PM
FXDWG12's Avatar
FXDWG12
Tire cupping could cause the problems that both of you have described also. But that issue is more of a factor of poor maintenance ( running low air pressure ). You may be able to see "cupping" if you look at the edge of the tire from the side. It will look wavey.
Old Sep 23, 2013 | 05:27 PM
1st 96 ultra's Avatar
1st 96 ultra
normally about 2 rear to a front , or more
Old Sep 23, 2013 | 05:31 PM
wndchsr2's Avatar
wndchsr2
thanks in advance
How often do you check your tire pressure? Have you greased the neck bearings?
Old Sep 23, 2013 | 06:19 PM
omaho5's Avatar
omaho5
Another way of checking for cupping that may not be visible is to run your hand
backward against the tread and feel it.
Old Sep 23, 2013 | 06:42 PM
Timpechos's Avatar
Timpechos
I have 23000+ on my front and 12000+ on my rear. The front needs replaced.
Old Sep 23, 2013 | 06:57 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
sometimes front tires will wear unevenly and go out of round,everytime I've had headshake was on older tire.new tire and headshakes gone.
