Saving Map with Power Vision
Old Sep 24, 2013 | 12:51 PM
mhud's Avatar
mhud
Default Saving Map with Power Vision
After you make a run with Auto Tune do you keep your bike running before you exit the data log. I've been cutting mine off first which does not allow the chance to exit data log. I'm looking to insure I/m saving the new map correctly. Thanks Guys.
Old Sep 24, 2013 | 12:53 PM
'05Train's Avatar
'05Train
I leave it running.
Old Sep 24, 2013 | 01:11 PM
JustDennis's Avatar
JustDennis
You must exit the data log before turning off the bike.
Old Sep 24, 2013 | 02:57 PM
skratch's Avatar
skratch
i've done this a couple times. so don't make the same mistake as me. export the learned values before you exit datalog or you lose everything
Old Sep 24, 2013 | 03:44 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Actually as of quite a while ago logs and Auto Tune corrections are automatically saved every 30 seconds, so if you shut the bike off before you end your logs you are still ok. Just to be safe run the update client and make sure your firmware is up to date.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Sep 25, 2013 | 04:41 AM
tpb857's Avatar
tpb857
I have had mine installed since April. I have always shut it off first without any problems.
IronHyena
Aug 5, 2016 08:06 PM
1_sik_glide
Mar 2, 2016 12:13 AM
rhallman
Jan 29, 2016 12:41 PM
Rhonda
Jun 11, 2011 07:45 PM
gpp
Oct 27, 2010 03:41 AM
