Oil Pressure Fluctuating
Old Sep 24, 2013 | 07:20 PM
PappyUSMC's Avatar
PappyUSMC
Default Oil Pressure Fluctuating
2009 Ultra, 60K, no mods.
Running fine. Sounds fine.
Stopped at gas station. Attempted to start it up. Horrible grinding sound. Stopped. Tried again, and started trying to start. Stopped. Tried again, started no problem.
Happened twice in same day. After second time, I noticed while riding the Oil Pressure gauge was constantly going from 5 to 31.. even while at same speed for a good distance.
Bike running fine, not noticeably hotter. Oil Temp gauge sits at 190 as normal for 40 min from work to home.
Ideas????
Clogged oil filter?
Old Sep 24, 2013 | 07:39 PM
Neil's Avatar
Neil
Crank could be scissoring and getting ready to eat your oil pump. Just a thought. Could also be a bad sender.
Neil
RDMC
dawg's Avatar
dawg
Even with the new tensioner system, at 60k I'd be checking them to be safe.
Old Sep 28, 2013 | 10:57 AM
PappyUSMC's Avatar
PappyUSMC
Crank scissoring... not understanding that reference.....
Old Sep 28, 2013 | 11:16 AM
dawg's Avatar
dawg
Crank shifts and causes excess runout.
Old Sep 28, 2013 | 12:57 PM
PappyUSMC's Avatar
PappyUSMC
Ahh ok.... how do I determine if that is it, and how do I correct it?
Old Sep 28, 2013 | 03:22 PM
dawg's Avatar
dawg
Would have to check crank runout. If excessive, cases would have to be split and crank trued and welded.
Old Sep 28, 2013 | 03:24 PM
dawg's Avatar
dawg
Could also be coincidental and the oil sending unit is faulty and has nothing to do with the noise. Noise as "grinding" when attempting to start could be starter clutch, issue with jack shaft and ring gear, etc.
Old Sep 28, 2013 | 03:33 PM
Stiggy's Avatar
Stiggy
dawg is correct as usual...But don't take this lightly. The cam cover on the right hand side needs to be pulled and the cam plate, oil pump and cams removed. The camshaft is now exposed and the use of a dial indicator while cranking the engine determines how "out of round" the crankshaft is.
If that's the problem, you rebuild the motor.
Clink, clank grind on hot restarts is common on '07 and later Twin Cams and may have nothing to do with the oil pressure.
One way or the other it needs to be checked out soon.
Old Sep 28, 2013 | 08:50 PM
lakedrum03's Avatar
lakedrum03
If it was in a cager I would say spun rod bearing. Not sure if that correlates to the bike world.
