Tranny Fluid?
Old Sep 25, 2013 | 11:04 PM
smitty901's Avatar
smitty901
The owners manual had said 32 oz however HD did put out a Service change.
The change was to drain and add 28 oz check then fill to proper level.
It seems some were draining it but not getting enough out dumping in the 32 oz and over filling them.
Old Sep 25, 2013 | 11:58 PM
the warden's Avatar
the warden
Originally Posted by FXDXTSport
How does that work for you. I was looking at it yesterday but ended up getting the Redline Shockproof that I've been using. I just completed a trip where I spent five of the ten days riding in 90+ degrees for hours. Thought the heavier (140) might be good for that but then thought it might get too heavy in cooler temps.
PMd you.
Old Sep 26, 2013 | 09:28 AM
hardheaded's Avatar
hardheaded
redline shockproof,1 quart,done deal
Old Sep 26, 2013 | 10:39 AM
FLUltrarider's Avatar
FLUltrarider
Originally Posted by pjb
do yourself a favor and use Redline Heavy Duty Shockproof trans fluid. Some call it "magic in a bottle".
I did, once, couldn't tell one bit of difference in mpg, noise, ease of shifting or any other factor the butt dyno could discern. Went back to the Syn3 and after 40,000 the tranny's still like new. I'm still convinced there may be miniscule differences in top-tier lubricants and gas, it's more a matter of keeping up with the maintenace at the recommended intervals versus what's going in the hole.
Old Sep 26, 2013 | 10:47 AM
Rickr01's Avatar
Rickr01
Originally Posted by the warden
Amsoil Severe Gear 75w-140 in mine.
+ 1 Works great for me..........Vermont mornings can range from 39-45F. Never an issue! Tranny is smooth as silk and quiet!
Old Sep 26, 2013 | 10:59 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Studies have shown that people who use one quart of Mobil 1 V-Twin 20w50 in the Harley tranny love their Mothers most.
I use Mobil 1 V-Twin 20w50 in all three holes because my Mother said I was special!
Old Oct 19, 2013 | 05:46 AM
artpe54's Avatar
artpe54
My manual for my 2013 calls for 28 oz, not 32.
Old Oct 19, 2013 | 06:01 AM
ynots's Avatar
ynots
Rocket science 101: buy a quart and insert 28 oz. if its not full add more.
Old Oct 19, 2013 | 11:07 AM
btsom's Avatar
btsom
A couple of points.
1. If the transmission was properly serviced BEFORE the fluid change and you want it at the proper level after the change, replace the amount that came out. The capacity of a dry unit does NOT necessarily indicate the RE-FILL amount needed. If due to internal contours, only a pint drains out (intentional exaggeration) and you pour in a quart of new juice, the unit will be waay over filled. If the new manual says the transmission has a 32 ounce capacity BUT refill with 28 ounces and then add as necessary to get the proper dip stick reading, the instruction is totally consistent with the idea that not all of the old fluid will drain.
2. Multi-viscosity lubes. A 75W-anything (75W-90, 75W-140, 75W-250) will only get as thick as a 75 lube when cold. The other number says how thin it will get when hot. If you are worried about flow when cold, it is the 75 part of the spec that you want to adjust, not the other number. Second, Gear lube viscosity uses a different scale than does motor oil. Using a viscosity test would show that 20-50 motor oil is about the same viscosity as 75-140 gear oil. That is just the way the SAE does it in an attempt to prevent confusing the lubes so that gear oil doesn't go into engines.
Old Oct 21, 2013 | 03:25 AM
NoCoLoco's Avatar
NoCoLoco
Get her good and hot, drain it as best as you can, pour in one quart (32oz) of 75W-140 GL-5 synthetic gear oil of your choice, close it up and forget about it! Change it at 20K miles OR once a year, whichever comes first
Ashnic
Milwaukee Eight (M8)
116
Aug 7, 2019 01:03 PM
Davemac122383
May 30, 2013 09:37 PM
jcmusic
May 1, 2011 09:30 PM
08roady
Apr 3, 2010 11:10 AM
anubisss
Oct 5, 2006 12:08 PM
