Big Bore Install - Issues
Old Oct 3, 2013 | 08:35 AM
2009's Avatar
2009
Piston slapping sounds more like a deep hollow sound lower in the engine. Kinda like a rod bearing knock or a wrist pin knock.
Noise goes away when you pull a spark plug wire.
Old Oct 3, 2013 | 09:27 AM
Fairshake's Avatar
Fairshake
You need to do several things before coming to any conclusions like piston slap which I'm willing to bet you don't have.Fill your tank with the highest octane fuel available in your area. If it is not at least 92, add a octane booster like the one from Amsoil. If your area has a problem with the amount of Ethanol in the fuel then add treatment for that also. Try dropping your plug range a little colder and use Iridium plugs.You stated that you installed high compression pistons but did not say what your final ratio is. Your builder needs to tell you what head gaskets were used and if they decked the heads any to raise the CP any higher.If you continue to run a pinging motor it will give up the ghost and let you know where the problem lies.
Old Oct 3, 2013 | 12:07 PM
GoofySB's Avatar
GoofySB
RE: slow cranking when hot.
I have a GS1100 with a 1166 kit in it. Compression was raised .25 from 10.25 to 10.50 I think. It also has aftermarket cams (Webb). It does not start as well when hot compared to cold. If it sits for 5 or 10 minutes all is fine again. IIRC.
I did two things that made it better. Replaced the ground and cleaned up the oil from the frame ground (right below breather tube (duh, what where they thinking)). Next I degreed the cams. They were off, maybe 5 degrees, its been a while.
Getting the cams right made the most difference. Having clean carbs so that it will fire up with minimal rotation helps too. BTW, its pretty fast.
Aside from that, I just attribute the slower cranking to the higher compression, cams and a starter/battery made for a stock bike.
Old Oct 3, 2013 | 12:36 PM
ke5rbd's Avatar
ke5rbd
[QUOTE=FL-kruzen;11832752]Thanks for the help guys. I put a whole freaking can of octane booster in and she quoted right down. Your right, I do have high compression pistons. The other issue I have noticed is after shutting down the engine when hot, it tends to be hard to restart for some reason. My bike Is Carbed with a Mikuni 42. What would cause a hard to start condition when hot?[/QUOTE
You didn't mention if it is not turning the engine normally or just not starting. If the engine is not turning good it is probably the high compression. If just not starting, it is probably flooding due to the carb having to be so rich at idle from not having a good vacuum signal. Try not pumping the throttle any and just cracking it slightly to keep the idle circuit from drawing fuel. If it is turning hard from high compression and no compression releases sometimes you can pump the throttle a couple of times and hold the throttle open about 1/2 way.
Old Oct 3, 2013 | 01:17 PM
fwb35's Avatar
fwb35
Mine is a little harder to start after the S&S 97 inch big bore went in, compression went from 9.3 to 9.7, mostly a little harder when it is hot like right after filling up with fuel, when I get my new S&S heads they will have compression releases.
Old Oct 3, 2013 | 05:01 PM
CBud's Avatar
CBud
What year is your GS1100? (Sorry for the hijack.)
Old Oct 3, 2013 | 05:49 PM
FL-kruzen's Avatar
FL-kruzen
I have no compression releases, my builder told me I can get by without them. I sure can hear the strain on the starter, but when she is cold, it starts right up.
Old Oct 3, 2013 | 06:30 PM
Gliden's Avatar
Gliden
I never get a slap when lugging.
Buddy got a slap after his 103 build.
A c clip was installed improperly on piston and the pin holding the piston to the rod popped off and pin was working it's way out.
Old Oct 4, 2013 | 06:52 AM
grbrown's Avatar
grbrown
Fit a more powerful starter motor! There are plenty out there, up to 2.4 kW. I have been using my stock starter on my S&S 107", which does have ACRs, but it finally gave up the ghost. You may well be able to 'get by', but a beefier starter will improve life!
Old Oct 4, 2013 | 11:24 AM
GoofySB's Avatar
GoofySB
GS1100E. It's an '83 frame with the red and has an 81 or 82 motor with a welded crank. I bought it in 2009 and since the motor was painted black, I assumed it was '83 also.
