Do the Beefier Front Forks Make a Difference on the 14's?
Old Sep 30, 2013 | 09:09 PM
  #31
$tonecold's Avatar
$tonecold
Originally Posted by grbrown
Unlikely, as the top and bottom trees are different, along with the steering bearings, so the frame of the 2014s is probably different to earlier models.
The main benefit of the 2014 forks is not the larger diameter of them IMHO, but the far superior top tree design, which at long last clamps the tops of the fork tubes firmly. Custom Cycle Engineering make a kit that does the same for older 41mm bikes, which should be cheaper than buying entirely new forks, as it uses your current sliders and internals. I have one ready to install!
I would like to hear your opinion after you install the new top clamp. Let us know if it makes a difference.
Old Sep 30, 2013 | 09:21 PM
  #32
Sc0-'s Avatar
Sc0-
Did Harley do any Geometry changes to the '14's front suspension compared to the '09-13's? I am thinking that they might have, or upgraded any other suspension bushings/bearings?
easy-wyatt
2014-2024 Touring Models
Sep 23, 2016 11:43 AM
muccimr
Aug 9, 2015 08:52 PM
steel cat 41
Mar 1, 2014 03:12 AM
luisan
Oct 16, 2010 08:10 AM
OldSalt
Aug 7, 2010 04:30 PM
