Stage 1
Old Sep 28, 2013 | 05:48 AM
hapbob's Avatar
hapbob
Default ok
Hey
Ok I guess I'll check out screemin...thought I was going to buy big sucka but I don't want it sticking out any more than it has to?
Is this different than just putting a K&N on stock set up..I'm confused again???
I have slipons and XIEDs thought I wanted to give a bit more air but no other changes?
Hap
Old Sep 28, 2013 | 05:55 AM
jg4660's Avatar
jg4660
I just put on an Arlen Ness and compared to the Screaming Eagle kit I also have it seems identical. It will only stick out more by the thickness of the bracket that is removed. I doubt you would notice.
JG
Old Sep 28, 2013 | 11:39 AM
midgetracer56's Avatar
midgetracer56
I just installed the Screamin Eagle AC on my '13 Roadglide Custom. Yes the bracket needs to be removed or the the backing plate will not bolt up to the throttle body. I was able to remove the bracket without lifting the tank. Just be patient it takes a little time to get the 2 allen bolts out, a long reach allen wrench makes the job easier, but I think the extra time it took me was equal to the time that it would have taken to unhook everything and lift the tank.
Old Sep 28, 2013 | 12:38 PM
Black_Hog's Avatar
Black_Hog
I just installed a SE air cleaner on my 2010 Ultra Classic along with a Cobra Fuel Management system. I lifted the fuel tank by loosening the front bolts and removing the three rear bolts. I used a 2X4 under the rear to hold the tank up. I didn’t have to unhook any hoses. I removed the bracket and installed two shorter stainless allen head bolts in the holes with a drop of blue Locktite. The original allen bolts were on very tight. I used a allen wrench and a box end wrench as leverage.
I used blue Locktite on all the fasteners.
I took my time (weather was nice and breezy) with the air cleaner and fuel management system and it took two hours for both including clean up.
Old Sep 29, 2013 | 07:46 AM
DAWG_6's Avatar
DAWG_6
Originally Posted by jg4660
I just put on an Arlen Ness and compared to the Screaming Eagle kit I also have it seems identical. It will only stick out more by the thickness of the bracket that is removed. I doubt you would notice. JG
The ness K&N filter is wider/deeper than the SE. I remember feeling it more on my RG I used to ride. Not a big deal, but it did stick out more.
Old Sep 29, 2013 | 07:51 AM
DAWG_6's Avatar
DAWG_6
Originally Posted by hapbob
Hey Ok I guess I'll check out screemin...thought I was going to buy big sucka but I don't want it sticking out any more than it has to? Is this different than just putting a K&N on stock set up..I'm confused again??? I have slipons and XIEDs thought I wanted to give a bit more air but no other changes? Hap
I have slip ons. & VIEDs on mine. You might as well get the kit rather than filter only. Looks much better than stock set up. I spoke to Steve @ Nightrider & he recommended I run mine @ 60-75% on my adjustment screws.
The big sucker filter is deeper than the SE filter. It's not crazy bigger, but I used to feel it on my RG.
Good luck
Old Sep 29, 2013 | 07:52 AM
DAWG_6's Avatar
DAWG_6
Good luck
Old Sep 29, 2013 | 07:57 AM
DAWG_6's Avatar
DAWG_6
Oops. Damn mobile app.
Old Sep 30, 2013 | 07:02 PM
hapbob's Avatar
hapbob
Default Dawg
Dawg what do you mean by get the kit vs the the filter only?
Hap
Old Sep 30, 2013 | 09:29 PM
SPECIAL ED's Avatar
SPECIAL ED
Would you have had to raise the tank if you had long allen wrenches or an allen socket on a long extension?? Just curious I never had to do that with my Dyna I know different animal but damn just to get the stock air box off, really.
