rinehart td ?
Old Mar 9, 2007 | 12:27 AM
ibridin's Avatar
ibridin
2nd Gear
Default rinehart td ?
Hi all
I am trying to install a set of Rinehart true duals. I get the front pipe on and try slipping the muffler on and it hits the axle nut. does anyone know how to coorect this? Havent even got to the rear pipe.
Old Mar 9, 2007 | 12:33 AM
Branded's Avatar
Branded
Default RE: rinehart td ?
Leave every thing loose until its all together. If you still have the muffler issue call Rineharts and they will send you a new pipe if thats the problem.
Old Mar 9, 2007 | 12:38 AM
raporte's Avatar
raporte
My buddy and I both did the TD's last year and had the same deal...right side hitting the axle nut. I remember others on this forum with same problem. I believe, with everything loose, grab the end of the muffler and twist counter-clockwise....should be able to get same spacing as left side and be okay. 'course there was some Jack consumed at the time, but I think that's all we did.
Respect to all......
Old Mar 9, 2007 | 12:39 AM
mlgoheen's Avatar
mlgoheen
exactly as branded said, I didn't tighten a bolt until everything was connected, nothing rubs, nothing rattles.
Old Mar 9, 2007 | 02:41 AM
rideon's Avatar
rideon
I ended up making a couple shims from the old muffler clamp and putting them between the tranny bracket and pipe. I probably could have got a new pipe, but for that simple fix I was up and running right away.
Check6
Jul 18, 2016 07:43 PM
57red
Jan 13, 2012 08:03 AM
cboehme
Mar 23, 2009 07:27 AM
ibridin
Exhaust System Topics
Mar 10, 2007 12:04 AM
redheadfred
Oct 10, 2006 10:15 PM
