Neutral rattle?
Old Sep 28, 2013 | 09:45 PM
Trucky911's Avatar
Trucky911
RIPSAW I have a friend with a 2013 with the loudest neutral rattle it makes a banging sound. The dealer told him it was normal.....
Trucky911
Old Sep 28, 2013 | 09:53 PM
Hausguy's Avatar
Hausguy
My compensator sprocket was replaced at about 22K on my 2012. I also have an occasional neutral rattle too especially after she's real warmed up. Asked the service guy about it and he asked if my previous bike was a metric....
Old Sep 29, 2013 | 05:31 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Trucky911
Sorry, did not know a banging sound was a neutral rattle.
Old Sep 29, 2013 | 06:15 AM
pdzani's Avatar
pdzani
I have a 2013 that starting making all kinds of noise in neutral when warmed up, this happened around 3K just before a 3K road trip. I would stop to fuel up, hit the starter and it sounded like rocks and marbles bouncing around. The noise started around the rear cylinder, transmission top area. I have had 9 harley bikes in 30 years of riding, 3 of them twin cams and I know what normal engine and valve train noise sounds like and this was not it.
Took it to my dealer before the trip, said it was normal. Took it to 2 dealers along my trip to make sure it was not going to self destruct. They both said neutral rattle, normal.
When I got home starting researching it on line, heard that adjusting the clutch rod to the low end of the spec 1/2 a turn out after it seats, may help. I was surprised that it did actually help to the point I hardly hear it anymore. I don't know if the engine vibration at idle caused the clutch rod to make this noise bouncing from the clutch side to the tranny side inside the main input shaft or not. There is alot of play inside the input shaft, (no seals) for that rod to bounce around, I know that from rebuilding the trans in my 09 ultra. All I know is that I was happy it stopped.
Old Sep 29, 2013 | 07:34 AM
hardheaded's Avatar
hardheaded
yep, mine does the same thing,more pronounced after it is warmed up. sloppy manufacturing and design is to blame. harley puts profits over everything else,even your safety.
Old Sep 29, 2013 | 11:02 AM
1Canuck's Avatar
1Canuck
posted originally by Dawg.
HD put out service bulletin M1304 for all 07 and later twin cams which states:
"When a motorcycle is at operating temperature and in neutral, a rattling sound may be heard on the right side coming from the area of the transmission side cover. This sound is normal and is referred to as neutral rattle. To verify the sound is neutral rattle, pull in the clutch lever and hold it for 10 to 15 seconds. If the sound stops, it is neutral rattle. Neutral rattle is caused by the necessary backlash within the first gear pair."
Old Sep 29, 2013 | 12:26 PM
UltraClassicElectraGlide's Avatar
Based on the Harley bulletin regarding neutral rattle, and having a pretty severe case of it with my bike, I'd say it isn't neutral rattle.
Since new, I've had an issue with a really loud bearing-like rattle at take off. (But only at take off.) It didn't happen every time and the dealer could never figure it out.
Fast forward to a couple of weeks ago: took the bike to an indy with this very complaint and they take it apart but everything seemed normal, though while putting it back together, the owner thought the primary chain looked loose and manually adjusted it. Have only been able to put about 80 miles on it since the repair, but it hasn't made the noise once.
The threads for the search for the problem and the resolution are posted here at HDForums.
Old Sep 29, 2013 | 03:16 PM
Guitardude's Avatar
Guitardude
I decided to spend a beautiful riding day wrenching bikes...that and put up a new garage door opener.
Decided to take the complete exhaust system OFF and as I was doing so found the problem. One of the heat shield clamps had a broken weld. Took me longer to get the Mig wire wielder cranked up than it did to tack it back together!
Gonna go finish the garage door opener and take a run around the 75 mile scenic loop of back roads and see what it does.
insp.clouseau
EVO
Apr 29, 2017 04:57 PM
graphicdisaster
Mar 27, 2017 08:31 AM
Slammed-N-Senseless
EVO
16
Nov 5, 2013 11:51 PM
Splais1
Aug 28, 2012 11:00 AM
diablo666
Aug 4, 2006 03:43 AM
