installing three horns
Old Sep 29, 2013 | 01:38 PM
sacchino's Avatar
sacchino
Default installing three horns
does anyone have a tutorial or a kid explanation, how to install two freewayblaster lo tone hi tone with the stock horn in a 2009 roadking?
i bought this cable and relay so should be pretty easy just don't where wiring goes
thanks
Old Sep 29, 2013 | 02:26 PM
dawg's Avatar
dawg
I took and replaced the stock horn with the low note and put the high note under the seat to the rear of the engine on a bracket I made. Wired through a relay and all is well. Why do you want to keep the stock horn and have 3? I would just use the high and low notes.
Old Sep 29, 2013 | 02:34 PM
sacchino's Avatar
sacchino
how should i wire them?
Old Sep 29, 2013 | 03:38 PM
dawg's Avatar
dawg
They get wired through a relay that you will have to add so you can use your horn switch to fire both horns. Google will show you wiring diagrams for wiring two horns through a relay. Not hard to do really.
Old Sep 30, 2013 | 07:05 AM
sacchino's Avatar
sacchino
let's see if i get this right from the picture attached, before melting my baby:
the black and red wire goes direct on the battery
the 4 clips are going two the new horns, one in the stock locatio and one in the new location
the quation is where the yellow goes? i gues i should solder it somewhere on the origianal wire, but i'm a bit confused where
sorry for the stupid question
Old Sep 30, 2013 | 10:22 AM
luisan's Avatar
luisan
Do you use the original horn housing for the new horn?Currently I have the Mini Beast (football) but I want to get rid of it in order to install Ward's fans but I still want loud horns.Thanks
Old Sep 30, 2013 | 01:54 PM
sacchino's Avatar
sacchino
can a yone post the electrical scheme about the horn switch and where it hoes or email it at sacchino@yahoo.com
thanks
Old Sep 30, 2013 | 05:33 PM
vzts4q's Avatar
vzts4q
thanks
Without knowing what relay you have there is no way we can give you a accurate answer.
Below is a good example of how it might work. The example shows 3 horns just like what you want to do.
http://www.rattlebars.com/avalanche/relay_basics.html
lmz5150
EVO
Mar 28, 2019 08:29 AM
flhrbill
Dec 22, 2016 06:55 PM
Mchad
Electrical/Lighting/Alarm
May 1, 2015 05:24 AM
Rodney54
Jul 22, 2013 02:46 PM
MarkR
Aug 7, 2007 01:34 PM
