Bagger wobble solved!
Old Oct 1, 2013 | 05:17 PM
shredder22's Avatar
shredder22
Porschemann, that is some great info. Thanks for taking the time to explain very clearly, I always like learning this stuff...
Old Oct 1, 2013 | 06:17 PM
James K's Avatar
James K
Are these the ones?
http://www.aliexpress.com/store/prod...473672118.html
Old Oct 1, 2013 | 06:29 PM
Sailrider 1's Avatar
Sailrider 1
Originally Posted by James K
Wow! If that's the same ones...............
Anyone know if an 03 has the same bearings as an 07 ?
Old Oct 1, 2013 | 07:58 PM
FreddyP's Avatar
FreddyP
According to Ronnie's Harley OEM online parts finder the 07 and 03 both use 9208 bearings, if that helps. You might want to verify at Ronnie's just in case I selected the wrong bike.
http://www.shopronniesharleydavidson...partfinder.htm
Old Oct 1, 2013 | 08:04 PM
Sailrider 1
Thanks, I'll check that site out.
Old Oct 1, 2013 | 11:11 PM
$tonecold's Avatar
$tonecold
I checked with Motion Industries today, the GE25ET-2RS from Aurora sells for less than $24 a piece. Aurora currently doesn't have any in stock and isn't going to manufacture any until the middle of December. Motion told me that it would probably be available in the middle of January which is OK with me. That should be about the time I'll want them.
Old Oct 2, 2013 | 08:10 AM
porschemann's Avatar
porschemann
No, those are not the bearings.... those are similar to the factory bearing. No seal, and use what I believe is a nylon sheet as the "lubrication" point which would be too soft and deflect almost immediately causing more play than the factory setup. Note the media says it is a "plain" bearing. Not sure what that means.
The best bearing for this application is the Aurora bearing that I specified. It is durable, high precision, and has seals on it. As to fitment years, I will look that up in my parts manual later today and post back here the factory part number. If your bike uses the same part number then it will fit yours too! If not, Aurora makes a host of different sizes and I'm sure you could source the correct one.
Old Oct 2, 2013 | 08:13 AM
porschemann
Here is a quick update on which bikes this bearing will fit. Factory bearing number is 9208 and this bearing fits the following models (to the best of my research)
2008 Harley-Davidson Electra Glide Classic (EFI) - FLHTC 2007 Harley-Davidson Electra Glide Classic (EFI) - FLHTC 2013 Harley-Davidson Electra Glide Classic - FLHTC 2012 Harley-Davidson Electra Glide Classic - FLHTC 2011 Harley-Davidson Electra Glide Classic - FLHTC 2010 Harley-Davidson Electra Glide Classic - FLHTC 2009 Harley-Davidson Electra Glide Classic - FLHTC 2005 Harley-Davidson Electra Glide Classic - FLHTC 2004 Harley-Davidson Electra Glide Classic - FLHTC 2003 Harley-Davidson Electra Glide Classic - FLHTC 2002 Harley-Davidson Electra Glide Classic - FLHTC 2008 Harley-Davidson Electra Glide Standard (EFI) - FLHT 2007 Harley-Davidson Electra Glide Standard (EFI) - FLHT 2009 Harley-Davidson Electra Glide Standard - FLHT 2006 Harley-Davidson Electra Glide Standard - FLHT 2005 Harley-Davidson Electra Glide Standard - FLHT 2004 Harley-Davidson Electra Glide Standard - FLHT 2003 Harley-Davidson Electra Glide Standard - FLHT 2002 Harley-Davidson Electra Glide Standard - FLHT 2006 Harley-Davidson Electra Glide Standard Injected - FLHT I 2005 Harley-Davidson Electra Glide Standard Injected - FLHT I 2004 Harley-Davidson Electra Glide Standard Injected - FLHT I 2003 Harley-Davidson Electra Glide Standard Injected - FLHT I 2008 Harley-Davidson Electra Glide Ultra Classic (EFI) - FLHTCU 2007 Harley-Davidson Electra Glide Ultra Classic (EFI) - FLHTCU 2012 Harley-Davidson Electra Glide Ultra Classic - FLHTCU 2011 Harley-Davidson Electra Glide Ultra Classic - FLHTCU 2010 Harley-Davidson Electra Glide Ultra Classic - FLHTCU 2009 Harley-Davidson Electra Glide Ultra Classic - FLHTCU 2006 Harley-Davidson Electra Glide Ultra Classic Injected - FLHTCU I 2005 Harley-Davidson Electra Glide Ultra Classic Injected - FLHTCU I 2004 Harley-Davidson Electra Glide Ultra Classic Injected - FLHTCU I 2003 Harley-Davidson Electra Glide Ultra Classic Injected - FLHTCU I 2002 Harley-Davidson Electra Glide Ultra Classic Injected - FLHTCU I 2013 Harley-Davidson Electra Glide Ultra Limited - FLHTK 2012 Harley-Davidson Electra Glide Ultra Limited - FLHTK 2011 Harley-Davidson Electra Glide Ultra Limited - FLHTK 2010 Harley-Davidson Electra Glide Ultra Limited - FLHTK 2008 Harley-Davidson Road Glide (EFI) - FLTR 2007 Harley-Davidson Road Glide (EFI) - FLTR 2009 Harley-Davidson Road Glide - FLTR 2002 Harley-Davidson Road Glide - FLTR 2013 Harley-Davidson Road Glide Custom - FLTRX 2012 Harley-Davidson Road Glide Custom - FLTRX 2011 Harley-Davidson Road Glide Custom - FLTRX 2010 Harley-Davidson Road Glide Custom - FLTRX 2006 Harley-Davidson Road Glide Injected - FLTR I 2005 Harley-Davidson Road Glide Injected - FLTR I 2004 Harley-Davidson Road Glide Injected - FLTR I 2003 Harley-Davidson Road Glide Injected - FLTR I 2002 Harley-Davidson Road Glide Injected - FLTR I 2013 Harley-Davidson Road Glide Ultra - FLTRU 2012 Harley-Davidson Road Glide Ultra - FLTRU 2011 Harley-Davidson Road Glide Ultra - FLTRU 2008 Harley-Davidson Road King (EFI) - FLHR 2007 Harley-Davidson Road King (EFI) - FLHR 2013 Harley-Davidson Road King - FLHR 2012 Harley-Davidson Road King - FLHR 2011 Harley-Davidson Road King - FLHR 2010 Harley-Davidson Road King - FLHR 2009 Harley-Davidson Road King - FLHR 2006 Harley-Davidson Road King - FLHR 2005 Harley-Davidson Road King - FLHR 2004 Harley-Davidson Road King - FLHR 2003 Harley-Davidson Road King - FLHR 2002 Harley-Davidson Road King - FLHR 2008 Harley-Davidson Road King Classic (EFI) - FLHRC 2007 Harley-Davidson Road King Classic (EFI) - FLHRC 2013 Harley-Davidson Road King Classic - FLHRC 2012 Harley-Davidson Road King Classic - FLHRC 2011 Harley-Davidson Road King Classic - FLHRC 2010 Harley-Davidson Road King Classic - FLHRC 2009 Harley-Davidson Road King Classic - FLHRC 2006 Harley-Davidson Road King Classic Injected - FLHRC I 2005 Harley-Davidson Road King Classic Injected - FLHRC I 2004 Harley-Davidson Road King Classic Injected - FLHRC I 2003 Harley-Davidson Road King Classic Injected - FLHRC I 2002 Harley-Davidson Road King Classic Injected - FLHRC I 2007 Harley-Davidson Road King Custom (EFI) - FLHRS 2006 Harley-Davidson Road King Custom - FLHRS 2005 Harley-Davidson Road King Custom - FLHRS 2004 Harley-Davidson Road King Custom - FLHRS 2006 Harley-Davidson Road King Custom Injected - FLHRS I 2005 Harley-Davidson Road King Custom Injected - FLHRS I 2004 Harley-Davidson Road King Custom Injected - FLHRS I 2006 Harley-Davidson Road King Injected - FLHR I 2005 Harley-Davidson Road King Injected - FLHR I 2004 Harley-Davidson Road King Injected - FLHR I 2003 Harley-Davidson Road King Injected - FLHR I 2002 Harley-Davidson Road King Injected - FLHR I 2008 Harley-Davidson Street Glide (EFI) - FLHX 2007 Harley-Davidson Street Glide (EFI) - FLHX 2013 Harley-Davidson Street Glide - FLHX 2012 Harley-Davidson Street Glide - FLHX 2011 Harley-Davidson Street Glide - FLHX 2010 Harley-Davidson Street Glide - FLHX 2009 Harley-Davidson Street Glide - FLHX 2006 Harley-Davidson Street Glide - FLHX 2006 Harley-Davidson Street Glide Injected - FLHX I
Old Oct 2, 2013 | 08:38 AM
equandt's Avatar
equandt
Great info here! porchemann, thanks for the info.
Old Oct 2, 2013 | 08:39 AM
grbrown's Avatar
grbrown
Wink
A plain bearing is simply one that has no ***** or rollers. A bronze bushing is also a plain bearing.
