ABS Light
Old Sep 30, 2013 | 12:35 PM
geigerglide's Avatar
geigerglide
Default ABS Light
I have a 2012 Road Glide and had the stock gauge faces painted, I did not like the way they turned out so I bought a used set of gauges from a bike that had ABS. My bike does not have ABS and the light stays on all the time. Does anyone know if there is a power wire to the tach gauge I could remove so the abs light stays off? Thanks for the help
Old Sep 30, 2013 | 01:12 PM
tOSUSteve's Avatar
tOSUSteve
You sure there is a different set of gauges for abs/non-abs??
Old Sep 30, 2013 | 02:19 PM
cfreeze's Avatar
cfreeze
same gauge, take it to the dealer turn it off with digi tech.
Old Sep 30, 2013 | 04:12 PM
BadBagger08's Avatar
BadBagger08
when you buy new gauges the will go either way abs/non abs, after about 30 miles they marry the bike it is installed on and can not be reversed. It is in the gauge now.
all gauges 2014 and newer will marry the bikes and can not be sold used, they will give error readings when swapped. It is this way also with all 2011 and newer Dayna model lines and all gauges utilizing the can-bus data line
06GliderGuy
Apr 1, 2015 08:56 PM
UltraClassicElectraGlide
Nov 20, 2013 07:51 AM
ggerline
Feb 6, 2013 03:15 PM
cbpbos
May 27, 2011 09:38 PM
fathertime
Sep 3, 2010 12:22 PM
