Compensator time, again!
Old Dec 6, 2013 | 08:29 AM
cardboard's Avatar
cardboard
Originally Posted by hd_rolling
Gluing is an option, you don't "have to". They recommend you install it but no ones going to open it up and check after you install. You could also by the 2014 primary cover that has this ne part already cast into the part so no plastic.
For me I'm going to glue it in, I'm not worried at all about the "Nasa" glue holding up or the plastic breaking apart.
Hopefully I don't have to eat my words!
Where did everybody go and get the T70 torx for it ?
Old Dec 6, 2013 | 09:31 AM
RAP's Avatar
RAP
http://www.ebay.com/itm/9573-TORX-SO...item2ec86d7851
hardheaded's Avatar
hardheaded
i was told snap on had them on back order for nearly a month. they sold out very fast when harley came out with the new models. don't waste your money on substandard tools. they are to soft to get the kinda torque you need for this bolt.
Old Dec 6, 2013 | 09:38 AM
RAP's Avatar
RAP
These ARE american made and worked great for when applying 175 ft pounds of torque.
Old Dec 6, 2013 | 10:10 AM
ohioflhs's Avatar
ohioflhs
As far as the leak goes, I think if I was in there, I would pull the plug and wire out of the hole from the inside as if I were replacing it and clean it. I might even use a little RTV while putting it back together.
Old Dec 6, 2013 | 10:34 AM
ftworthcowboy's Avatar
ftworthcowboy
Just had my comp and rotor replaced with the SE while in the shop for starter replacement all on extended warranty, at 41k
Old Dec 6, 2013 | 10:46 AM
hardheaded's Avatar
hardheaded
did you get the new 14 comp. installed and of so ,how do you like it?
Guntoter's Avatar
Guntoter
http://www.ebay.com/itm/1-2-Dr-T70-I...d120da&vxp=mtr
I bought this socket, a Sunex impact T70, off Amazon but they are sold out now. Looks to be a pretty good quality tool. I also bought a Lisle T70 but not sure how that will do with the high torque.
Old Dec 6, 2013 | 10:55 AM
smithbrl's Avatar
smithbrl
New compensator came in today, clutch came a couple days ago. Just need a new primary case gasket and everything goes in. Wonder what the seat of the pants is going to feel like with a both being new?
Just curious. How's the project coming?
Fine09
Apr 18, 2024 08:23 PM
bellmnbell
Feb 27, 2017 07:35 PM
danzio
Jun 1, 2014 04:02 PM
Mike
Jul 31, 2011 09:57 PM
harleyboy63401
Sep 22, 2005 04:03 PM
