Got mine 120 bucks shipped from mom-n-pop off of fleabay (dunno if they are still doing it or not) cant even tell the pipe was messed with and he coated the entire pipe with black bbq paint no extra charge, that along with xieds and a big sucker, throttle is snappier, bike is happy now and not runnin hot, total is less than 600 in the entire stage 1, couldnt be happier. Good luck with your bike dude, stay safe.
I'm pretty sure I'm going to go with the Jackpot 2-1-2 ceramic coated header pipe on my 2014 Limited mostly for heat reduction. That cat area is crazy hot on the stock pipe.
I've read that tuning the individual cylinders is all but impossible with a stock decated head pipe due to the close positioning of the O2 sensors.
Guys most everybody either has or knows someone with a die grinder or dremel tool. Make 3 1/2 cuts and dig the cat out your self and take and get it welded up. 50 bucks max. It pretty easy once you get into it. You might even be able to talk one of the local shops into "donating" a stock header pipe to de-cat so you can keep you original one stock just in case. Anyway you look at it that's more then adequate for a near stock or a build most people will do and a whole lot cheaper.
I remember the day I took off the stock headers and grabbed the V&H header out the box. It's the same diameter pipe as stock. For some reason I thought a "header" pipe would be larger. Same pipe with no cat.
