How difficult to replace my own stator?
Old Oct 6, 2013 | 01:54 PM
Joltergeist's Avatar
Joltergeist
All great suggestions... I'm not insulted at all, will yank the battery and run it up to Batteries Plus to have it tested. Also will check the connections and circuits as recommended. If I don't have to replace the stator then I don't want to do it. Thanks for the ideas on how to troubleshoot!!
Old Oct 6, 2013 | 03:09 PM
Joltergeist
Originally Posted by hdbob2006
More likely a problem like mkguitar showed,or a regulator. If you have a HD manua,there will be instructions to test your stator. It'd be a waste to change the stator if it's not the problem. I've had many bad regulators on Harleys,never had a bad stator-thought I did one time,but it was a bad plug in on the end where it goes through the primary case.
I have the HD Service Manual, but there do not appear to be instructions for testing the stator... says to use the electrical diagnostic manual. Anyone got a copy of the testing procedure?
Old Oct 6, 2013 | 04:47 PM
sargek's Avatar
sargek
There are a couple of threads on here about doing this. I did it myself but didn't use the HD parts - bought a complete stator and regulator kit from Cycle Electric. Works great and I have no idea how long it took me because I did the tear down one day and assembly another day. I did have to grind the primary to get the rotor off but it's easy with a dremel - just need to be careful about cleaning up afterwards.
Old Oct 6, 2013 | 05:32 PM
TUCCI's Avatar
TUCCI
I though it extremely difficult until I had to remove the comp sprocket and there it was right behind it, so I would say it's not too tough if you do some self learning and prep work.
Old Oct 6, 2013 | 06:48 PM
Deucedog's Avatar
Deucedog
Grab a beverage and watch these.
Old Oct 6, 2013 | 07:33 PM
lp's Avatar
lp
Could be just the voltage regulator... I guess.
lp
Old Oct 6, 2013 | 08:44 PM
Joltergeist
Originally Posted by lp
Could be just the voltage regulator... I guess. lp
I was looking at the service manual and thought the same thing
Joltergeist
Rock on... Thanks!
Old Oct 6, 2013 | 08:52 PM
hanny's Avatar
hanny
sounds exactly like a regulator issue to me or even more likely the connection to it can be a little loose with some corrosion on it.
To check the connection the next time the gauge goes low keep the bike running and wiggle the connection on the regulator,,,,,,,,,, I bet it starts charging....
To fix, take the connector loose, clean it with brake cleaner, let dry, use dielectric grease on it then plug back in. walla
Old Oct 6, 2013 | 09:52 PM
Joltergeist
Originally Posted by hanny
sounds exactly like a regulator issue to me or even more likely the connection to it can be a little loose with some corrosion on it. To check the connection the next time the gauge goes low keep the bike running and wiggle the connection on the regulator,,,,,,,,,, I bet it starts charging.... To fix, take the connector loose, clean it with brake cleaner, let dry, use dielectric grease on it then plug back in. walla
Been riding thru some hefty rain storms so that sounds like it could be the culprit. Plan on checking it out tomorrow!
