How difficult to replace my own stator?
Old May 26, 2014 | 09:20 AM
  #31
Joltergeist's Avatar
Joltergeist
I've replaced the regulator, tested the stator and it passed I believe. I've pulled all aftermarket accessories off the battery completely and still have the problem. I will trace the battery lead wires and check them next. If it isn't that I will have to take it to the dealer for more help. I'm really at a loss here.
When I tested the stator the ignition switch was off, my multimeter showed 0 ohms as the video linked above said it should.
Not sure where else to look now other than the battery cables
Old May 26, 2014 | 09:29 AM
  #32
lp's Avatar
lp
With a multimeter:
What is the voltage at the battery terminals with the bike off? ______ (Mine 12.64)
What is the voltage at the battery terminals with the bike running and idling? ______ (Mine 14.05)
What is the voltage at the battery terminals with the bike running at 2K RPM? ______ (Mine 14.05)
lp
Old May 26, 2014 | 09:39 AM
  #33
Joltergeist
Originally Posted by lp
With a multimeter: What is the voltage at the battery terminals with the bike off? ______ (Mine 12.64) What is the voltage at the battery terminals with the bike running and idling? ______ (Mine 14.05) What is the voltage at the battery terminals with the bike running at 2K RPM? ______ (Mine 14.05) lp
At idle, it varies, between 11 and 14. It appears to be intermittent. however the other readings are same as yours. Battery reads 12.6 with switch off and 14.2 at 2k rpm.
I've seen the varying voltage at traffic lights using my PowerVision tuner with the battery voltage gauge displaying
Old May 26, 2014 | 09:55 AM
  #34
lp's Avatar
lp
Ok cool.
More checks just to baseline:
Bike off, ignition switch to off _____ (12.64)
Bike off, ignition switch to "Ignition" position, spots off, radio on, headlight on (obviously) _____ (12.15)
Bike off, ignition to Accessory position, radio on _____ (12.43)
Bike off, ignition to Accessory position, radio off _____ (12.41)
lp
Old May 26, 2014 | 10:24 AM
  #35
Joltergeist
Ok cool.
lp
All right around 12/11.9/11.8
Old May 26, 2014 | 10:41 AM
  #36
lp's Avatar
lp
So you go from 12.6 off to 11.8 on (ignition) fogs off/radio on? That actual?
That's a loss of .8 volts. You have something drawing a lot of current with the bike on and it's not your spots or radio (if your spots were actually off)
I only have a .4 drop at the battery with spots off/radio on and only .5 drop with spots on even for conversation's sake.
So something is drawing more current than most (at least mine) so that is why the fluctuation and dim lights at idle probably.
Nothing else wired in there somewhere? Could be loss through your power or ground wire too. Have you tried addressing those areas?
Btw I meant 12.41 radio on and 12.43 radio off above. Sorry but I think you knew what I meant.
lp
Old May 26, 2014 | 10:50 AM
  #37
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Disconnect both connectors of the VR, start the engine and observe your voltmeter.
The alternator will see no load (Open Circuit) and can run without damage.
You will rely 100% on the battery and should have a steady condition.
If this is not the case you have to inspect all power connections including fuses. The next step is to search for a broken wire, which is a pain in other words.
Old May 26, 2014 | 10:56 AM
  #38
Joltergeist
Originally Posted by Expat1
Disconnect both connectors of the VR, start the engine and observe your voltmeter. The alternator will see no load (Open Circuit) and can run without damage. You will rely 100% on the battery and should have a steady condition. If this is not the case you have to inspect all power connections including fuses. The next step is to search for a broken wire, which is a pain in other words.
I have this problem with and without the aftermarket accessories connected. I know now after all this troubleshooting that I have a wire that needs replacing, just finding which one is the hard part now.
Old Jun 5, 2017 | 07:20 AM
  #39
Jody Honeycutt's Avatar
Jody Honeycutt
Stage III
Default 2006 flhtcui stator
Are there any videos to show how to do stator/regulator...replacement on above mentioned bike? I know we can do it, just need some instruction. Thanks
Old Jun 5, 2017 | 07:45 AM
  #40
Cpl Ed's Avatar
Cpl Ed
Here's a menu you can choose from:
